Component: Injector (Flowcode vNet) (Test Injectors)
Revision as of 09:57, 27 January 2023 by Wiki bot (talk | contribs)
Category Test Injectors
Injector (Flowcode vNet) component
Comms data injector to allow components to talk to each other between instances of Flowcode. The injector allows the data to be sent and received between multiple instances of Flowcode either running on a single machine, across a network or via the internet.
Please click here to download the component source project: FC_Comp_Source_InjectorVnet.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_InjectorVnet.fcfx
Simple Single Instance
Sends out data and prints incoming data to an LCD. Uses the same port number for transmit and receive.
SingleInstanceVnet
Simple Multi Instance
The first program sends out data.
UartVnetDemoTx
The second program receives the data and prints to an LCD.
UartVnetDemoRx
Remote Lock
Here is an example of using the vNet injector to simulate a multi microcontroller system.
Microcontroller 1 is connected to a keypad and has a RS232 communications connection.
Microcontroller 2 is connected to a solenoid and has a RS232 communications connection.
Any key presses detected on microcontroller 1 will be sent via RS232 to microcontroller 2. If the correct byte sequence (1234) is received by microcontroller 2 then the solenoid is fired to unlock a door for 5 seconds.
vNet Example Node 1
vNet Example Node 2
Communications over the vNet injector can be monitored using the console.
Modbus Master and Slave example using vNet
Example of communicating using Modbus Master and Slave using two instances of Flowcode and the vNet injector component.
ModbusMasterDemo
ModBusSlaveDemo
UARTBaud
- BYTE Channel
- BYTE Rate
IOGetInputPin
- BYTE Pin
- BOOL Return
UARTCheckRX
- BYTE Channel
UARTInitialise
- BYTE Channel
UARTReceive
- BYTE Channel
IOSetOutputPin
- BYTE Pin
- BOOL State
UARTSend
- BYTE Channel
- BYTE Data
vNet Injector Settings
Network Interface
Allows different network interfaces to be selected. The current network interface can be determined by looking at the My IP properties.
Incoming Channel
TCP Channel Instance, allows multiple servers and clients to run on the same machine or inside the same simulation.
Incoming Port
Port used for incoming communications. 80=HTTP Ports have to match up to allow communications to be sent and received.
Outgoing Channel
Outgoing Port
Port used for outgoing communications. 80=HTTP Ports have to match up to allow communications to be sent and received.
Connection Mode
Specified if this Vnet node is going to connect to another instance of Flowcode running on this PC or a networked PC.
Circular Buffer Size
Size of the circular buffers used to temporarily store the incoming and outgoing data.
Local IP
My IP0
Local IP address byte 0
My IP1
Local IP address byte 1
My IP2
Local IP address byte 2
My IP3
Local IP address byte 3
Show Console
UARTBaud
- BYTE Channel
- BYTE Rate
IOGetInputPin
- BYTE Pin
- BOOL Return
UARTCheckRX
- BYTE Channel
UARTInitialise
- BYTE Channel
UARTReceive
- BYTE Channel
IOSetOutputPin
- BYTE Pin
- BOOL State
UARTSend
- BYTE Channel
- BYTE Data
Network Interface
Incoming Channel
Incoming Port
Outgoing Channel
Outgoing Port
Connection Mode
Local IP
My IP0
My IP1
My IP2
My IP3
Show Console
UARTBaud
- BYTE Channel
- BYTE Rate
IOGetInputPin
- BYTE Pin
- BOOL Return
UARTCheckRX
- BYTE Channel
UARTInitialise
- BYTE Channel
UARTReceive
- BYTE Channel
IOSetOutputPin
- BYTE Pin
- BOOL State
UARTSend
- BYTE Channel
- BYTE Data
Network Interface
Incoming Channel
Incoming Port
Outgoing Channel
Outgoing Port
Connection Mode
Local IP
My IP0
My IP1
My IP2
My IP3
Show Console
UARTBaud
- BYTE Channel
- BYTE Rate
IOGetInputPin
- BYTE Pin
- BOOL Return
UARTCheckRX
- BYTE Channel
UARTInitialise
- BYTE Channel
UARTReceive
- BYTE Channel
IOSetOutputPin
- BYTE Pin
- BOOL State
UARTSend
- BYTE Channel
- BYTE Data
Network Interface
Incoming Channel
Incoming Port
Outgoing Channel
Outgoing Port
Connection Mode
Local IP
My IP0
My IP1
My IP2
My IP3
Show Console
