Component: LED Array (LEDs)
Revision as of 09:58, 27 January 2023 by Wiki bot (talk | contribs)
Category LEDs
LED Array component
An array of LED indicators equally spaced and complete with labels to indicate their meaning. Embedded can be used to control an 8-bit port or up to 8 individual pins.
Please click here to download the component source project: FC_Comp_Source_LED_Array_2dgi.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_LED_Array_2dgi.fcfx
Each segment will require a current limiting resistor.
LED Resistor Calculator Tool
Simple Counter
This example counts up from 0 to 9 on the 7-segment display before wrapping back to 0 and starting again. When displaying odd numbers we light the decimal point segment. FC6 Icon.png 7Segment Display Example
Multiplexed Counter
This next example counts up from 0 to 99 on two 7-segment displays before wrapping back to 0 and starting again. The two displays are driven using a technique called multiplexing. A timer interrupt is used to perform the multiplexing leaving our program free to perform other tasks. Each 7-segment display shares the same segment pin connections but has a unique common pin connection to allow each individual 7-segment display to display a unique value. FC6 Icon.png 7Segment Multiplex
Stop Watch
This next example uses a timer interrupt to multiplex between the displays and a second timer interrupt to count the passing of time allowing for accurate timings. Using four single 7-seg components we create a timer capable of monitoring time from 0.0 to 999.9 seconds in multiples of 100ms. The second timer interrupt flags to the main when the count value has changed allowing the heavier calculations to extract the digits from the counter to be done outside of the high speed interrupt routine and therefore maintain accurate timing.
Switches connected to Port D allow for the timer to be started, stopped and reset. FC6 Icon.png 7Segment Timer
Segment Control
This example shows a method to display custom characters on 7-segment displays and also allows for numeric values to be displayed.
FC6 Icon.png 7Segment Character Demo
Fc9-comp-macro.png BarGraph
Turns on the first N elements of the array - for generating bar graph metes etc.
Fc9-u8-icon.png - BYTE Length
How many items to light up.
Fc9-comp-macro.png LEDOn
Turn on the selected LED.
Fc9-u8-icon.png - BYTE Index
Index of the LED to turn on.
Fc9-comp-macro.png AllOn
Turns on all elements
Fc9-comp-macro.png LEDOff
Turn off the selected led.
Fc9-comp-macro.png PointGraph
Turns on the Indexed LED and turns all others off. Does nothing if the index is out of range.
The LED to show.
Fc9-comp-macro.png WriteValue
Write a number which is presented on the LEDs in binary.
Fc9-u8-icon.png - BYTE Value
Provide a value to be written to the LEDs in binary
Fc9-comp-macro.png AllOff
Turns off all elements
Fc9-type-16-icon.png Count
The number of LEDs in the array from 1 to 8.
Fc9-type-16-icon.png Output Mode
Fc9-type-19-icon.png Port
Fc9-type-16-icon.png Polarity
Fc9-conn-icon.png Simulation
Fc9-type-16-icon.png Switch layout
Fc9-type-21-icon.png Distance between LEDs
Fc9-type-2-icon.png Label colour
Fc9-type-7-icon.png Show Connection Label
If enabled, the pin designation will be shown, e.g. B0.
Fc9-type-7-icon.png Show Pin Value
Pin status of VCC or GND will be shown when enabled and simualtion is running.
Fc9-conn-icon.png Appearance
Fc9-type-16-icon.png Shape
Fc9-type-16-icon.png Colour
Fc9-type-16-icon.png Style
The LED to show.
The LED to show.
The LED to show.
