Component: LoRa (LAMBDA SX1272) (LAMBDA SX1272) (Wireless)
Revision as of 09:58, 27 January 2023 by Wiki bot (talk | contribs)
Category Wireless
LoRa (LAMBDA SX1272) component
Component to drive the LAMBDA LoRa Transciever module from RF Solutions. Uses an SPI bus connection to the microcontroller. Uses the Semtech SX1272 Transciever IC.
Please click here to download the component source project: FC_Comp_Source_LoRa_Lambda.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_LoRa_Lambda.fcfx
Fc9-comp-macro.png ReadReg
Reads a register on the device and returns the value read
Fc9-comp-macro.png ReceiveBuffer
Attampt to read a number of bytes from the LoRa network. Returns the number of bytes received
Fc9-u8-icon.png - BYTE Data
Fc9-u8-icon.png - BYTE Count
Fc9-u16-icon.png - UINT Timeout
Time to wait in milliseconds
Fc9-comp-macro.png WriteReg
Fc9-u8-icon.png - BYTE Value
Fc9-comp-macro.png TransmitBuffer
Attampt to send a number of bytes to the LoRa network.
Data buffer to transmit
Number of bytes to send
Fc9-comp-macro.png SetFrequency
Sets the module frequency
Fc9-u32-icon.png - ULONG Frequency
Fc9-comp-macro.png Initialise
Starts the SPI and configures the LoRa module frequency
Fc9-conn-icon.png LoRa Properties
Fc9-type-21-icon.png Frequency
Fc9-type-16-icon.png Channel
SPI Channel selector
Fc9-type-16-icon.png Prescale
Prescale option selector
Fc9-type-5-icon.png MOSI
Fc9-type-5-icon.png MISO
Fc9-type-5-icon.png CLK
Fc9-type-5-icon.png CS / SS
Fc9-type-5-icon.png RX Switch
Fc9-type-5-icon.png TX Switch
Fc9-conn-icon.png Simulation
Fc9-type-7-icon.png Simulate comms
