Component: Digital Potentiometer (MCP44XX) (Analog Output)
| Category | Analog Output |
Digital Potentiometer (MCP44XX) component
The MCP44XX device range supports 4 digital potentiometers or rheostat outputs. 129 or 257 possible output resistance values for each channel.
Please click here to download the component source project: FC_Comp_Source_MCP44xx_Digital_Pot.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_MCP44xx_Digital_Pot.fcfx
|   | IncrementWiper |
| Increments a single volatile wiper value | |
|  - BYTE | Index |
| Range: 0-3 | |
|  - VOID | Return |
|   | DecrementWiper |
| Decrements a single volatile wiper value | |
|  - BYTE | Index |
| Range: 0-3 | |
|  - VOID | Return |
|   | SetWiper |
| Sets the value of a single wiper | |
|  - BYTE | Index |
| Range: 0-3 | |
|  - UINT | Value |
| 129 Taps Range: 0-128 / 257 Taps Range: 0-256 | |
|  - BOOL | MemoryType |
| 0=Volatile, 1=Nonvolatile | |
|  - VOID | Return |
|   | ReadAddress |
| Reads a value from one of the registers on the device | |
|  - BYTE | Address |
| Range: 0-15 | |
|  - UINT | Return |
|   | WriteAddress |
| Writes a value to one of the registers on the device | |
|  - BYTE | Address |
| Range: 0-15 | |
|  - UINT | Value |
| Range: 0-256 | |
|  - VOID | Return |
|   | Initialise |
| Startup the I2C peripheral ready for communications. | |
|  - VOID | Return |
|   | IncrementWiper |
|  - BYTE | Index |
| Range: 0-3 | |
|  - VOID | Return |
|   | DecrementWiper |
|  - BYTE | Index |
| Range: 0-3 | |
|  - VOID | Return |
|   | SetWiper |
|  - BYTE | Index |
| Range: 0-3 | |
|  - UINT | Value |
|  - VOID | Return |
|   | ReadAddress |
|  - BYTE | Address |
| Range: 0-15 | |
|  - UINT | Return |
|   | WriteAddress |
|  - BYTE | Address |
| Range: 0-15 | |
|  - UINT | Value |
| Range: 0-256 | |
|  - VOID | Return |
|   | Initialise |
|  - VOID | Return |
|   | IncrementWiper |
|  - BYTE | Index |
| Range: 0-3 | |
|  - VOID | Return |
|   | DecrementWiper |
|  - BYTE | Index |
| Range: 0-3 | |
|  - VOID | Return |
|   | SetWiper |
|  - BYTE | Index |
| Range: 0-3 | |
|  - UINT | Value |
|  - VOID | Return |
|   | ReadAddress |
|  - BYTE | Address |
| Range: 0-15 | |
|  - UINT | Return |
|   | WriteAddress |
|  - BYTE | Address |
| Range: 0-15 | |
|  - UINT | Value |
| Range: 0-256 | |
|  - VOID | Return |
|   | Initialise |
|  - VOID | Return |
|   | IncrementWiper |
|  - BYTE | Index |
| Range: 0-3 | |
|  - VOID | Return |
|   | DecrementWiper |
|  - BYTE | Index |
| Range: 0-3 | |
|  - VOID | Return |
|   | SetWiper |
|  - BYTE | Index |
| Range: 0-3 | |
|  - UINT | Value |
|  - VOID | Return |
|   | ReadAddress |
|  - BYTE | Address |
| Range: 0-15 | |
|  - UINT | Return |
|   | WriteAddress |
|  - BYTE | Address |
| Range: 0-15 | |
|  - UINT | Value |
| Range: 0-256 | |
|  - VOID | Return |
|   | Initialise |
|  - VOID | Return |
