Component: Magnetometer 3-Axis (HMC5883L) (Movement Orientation)
Revision as of 09:58, 27 January 2023 by Wiki bot (talk | contribs)
Version 1.6
Category Movement Orientation
Magnetometer 3-Axis (HMC5883L) component
HMC5883L 3-Axis Magnetometer sensor Useful for working out data such as compass orientation.
Please click here to download the component source project: FC_Comp_Source_Magnetometer_HMC5883.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Magnetometer_HMC5883.fcfx
Here is a very simple demonstration on how to use the sensor to read X, Y, Z magnetometer data from the sensor.
HMC5883L Demo
Read_Register
Reads a value from a register on the accelerometer.
- BYTE Reg
Write_Register
Writes a data value to a specific register on the accelerometer
- BYTE Reg
- BYTE Data
UpdateCompassData
Reads from the compass and updates the local XYZ variables. Returns 1 for new data and 0 for no new data
CollectXYZData
Collect the data from the local accelerometer buffers. The Axis parameter specifies the Axis to be read. 0 / 'x' / 'X' - X axis 1 / 'y' / 'Y' - Y axis 2 / 'z' / 'Z' - Z axis
- BYTE Axis
- INT Return
SimSetCompass
Allows the XYZ slider values to be set via the simulation
- INT X
- INT Y
- INT Z
Read_Bearing
Reads the current sensor compass bearing based on degrees CW from magnetic north. Returns 0-359 where 0 = North, 90 = East, 180 = South, 270 = West Requires the ArcTan floating point function to be available to work correctly. Supported on AVR, 16-bit
- BYTE NumSamples
The number of readings to base the bearing on
Sets up up the communication bus and initialises the accelerometer module. Returns 0 for success and > 0 for fail.
Bit Depth
Measurement Mode
Continuous mode makes constant sensor readings setting the RDY pin when new data is available. Single mode does a single sensor read setting the RDY pin when done and then waits for data to be read.
Num Samples
The number of samples that are averaged together to provide the readings.
Compass Data Rate
Sets the output conversion rate.
Compass Scale
Channel selection
Baud Select
Baud rate to be used
Stop Delay
SDA
SCL
Use RDY Pin
Simulate Comms
Yes: Accelerometer data will come from the simulation component sliders. No: Accelerometer data will come from the I2C CAL component - Injector etc
Read_Register
- BYTE Reg
Write_Register
- BYTE Reg
- BYTE Data
UpdateCompassData
CollectXYZData
- BYTE Axis
- INT Return
SimSetCompass
- INT X
- INT Y
- INT Z
Read_Bearing
- BYTE NumSamples
Bit Depth
Measurement Mode
Num Samples
Compass Data Rate
Compass Scale
Channel selection
Baud Select
Stop Delay
SDA
SCL
Use RDY Pin
Simulate Comms
Read_Register
- BYTE Reg
Write_Register
- BYTE Reg
- BYTE Data
UpdateCompassData
CollectXYZData
- BYTE Axis
- INT Return
SimSetCompass
- INT X
- INT Y
- INT Z
Read_Bearing
- BYTE NumSamples
Bit Depth
Measurement Mode
Num Samples
Compass Data Rate
Compass Scale
Channel selection
Baud Select
Stop Delay
SDA
SCL
Use RDY Pin
Simulate Comms
Read_Register
- BYTE Reg
Write_Register
- BYTE Reg
- BYTE Data
UpdateCompassData
CollectXYZData
- BYTE Axis
- INT Return
SimSetCompass
- INT X
- INT Y
- INT Z
Read_Bearing
- BYTE NumSamples
Bit Depth
Measurement Mode
Num Samples
Compass Data Rate
Compass Scale
Channel selection
Baud Select
Stop Delay
SDA
SCL
Use RDY Pin
Simulate Comms
