| Author
Matrix TSL
| Version
1.0
| Category
Movement Orientation
Magnetometer (SM324) component
SM324 ultraprecise 24-bit smart magnetometer capable of distance measurement using a magnet. Controlled via I2C bus communications.
Please click here to download the component source project: FC_Comp_Source_Magnetometer_SM324.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Magnetometer_SM324.fcfx
ReadStatus
| Reads the status byte from the sensor IC. Bit 6 = Voltage OK Bit 5 = Busy Bit 2 = Memory Error Bit 0 = Saturation
- BYTE
WriteMemory
| Writes a 16-bit value to the specified memory location
- BYTE
Address
| Internal memory address
- UINT
Value
RequestData
| Requests temperature and magnetic data from the device, returns status. Bit 6 = Voltage OK Bit 5 = Busy Bit 2 = Memory Error Bit 0 = Saturation
- BYTE
ReadTemperatureRaw
| Reads the temperature from the last succesful data read.
- LONG
ReadMagneticFieldRaw
| Reads the magnetic field from the last succesful data read.
- LONG
ReadMagneticFieldReal
| Reads the magnetic field from the last succesful data read as a float in Oersted Oe.
- LONG
SetAddress
| Configures the device address used to communicate with sensor IC. Optionally writes the new address to the sensor IC NVM.
- BYTE
Address
| The new address of the sensor IC, Range 8-127
- BOOL
WriteToIC
| Writes the new address to the IC NVM 1=Write, 0=Don't Write
WriteCommand
| Sends a command to the sensor IC.
- BYTE
Command
ReadTemperatureReal
| Reads the temperature from the last succesful data read as an float in degrees C.
- FLOAT
| Sets up the I2C bus ready to communicate with the sensor IC. Sets the address variable back to the Address property value.
Sensor Properties
Cyclic Mode
I2C Properties
| Channel selection
Address
| Address of the SM324 IC, Default address is 16. Valid Address range = 8 to 127
SDA
SDA Remap Pin
SCL
SCL Remap Pin
Stop Delay
Baud Select
| Baud rate option selector
| Baud rate to be used
Threshold Output
Threshold Pin
| The pins used to check the DOUT pin on the SM324,
Threshold Setting
| Controls the function of the sensor IC DOUT pin.
Threshold1
| Threshold 1 Value
Threshold2
| Threshold 2 value. If Thresh1 > Thresh2 1: Measurement > Thresh1 OR Measurement < Thresh2 0: Thresh1 > Measurement > Thresh2 If Thresh2 > Thresh1 1: Thresh1 > Measurement > Thresh2 0: Measurement > Thresh2 OR Measurement < Thresh1
Simulate Comms
ReadStatus
- BYTE
WriteMemory
- BYTE
Address
- UINT
Value
RequestData
- BYTE
ReadTemperatureRaw
- LONG
- LONG
- LONG
SetAddress
- BYTE
Address
- BOOL
WriteToIC
WriteCommand
- BYTE
Command
ReadTemperatureReal
- FLOAT
Sensor Properties
Cyclic Mode
I2C Properties
| Channel selection
Address
SDA
SDA Remap Pin
SCL
SCL Remap Pin
Stop Delay
Baud Select
Threshold Output
Threshold Pin
Threshold Setting
Threshold1
| Threshold 1 Value
Threshold2
Simulate Comms
ReadStatus
- BYTE
WriteMemory
- BYTE
Address
- UINT
Value
RequestData
- BYTE
ReadTemperatureRaw
- LONG
- LONG
- LONG
SetAddress
- BYTE
Address
- BOOL
WriteToIC
WriteCommand
- BYTE
Command
ReadTemperatureReal
- FLOAT
Sensor Properties
Cyclic Mode
I2C Properties
| Channel selection
Address
SDA
SDA Remap Pin
SCL
SCL Remap Pin
Stop Delay
Baud Select
Threshold Output
Threshold Pin
Threshold Setting
Threshold1
| Threshold 1 Value
Threshold2
Simulate Comms
ReadStatus
- BYTE
WriteMemory
- BYTE
Address
- UINT
Value
RequestData
- BYTE
ReadTemperatureRaw
- LONG
- LONG
- LONG
SetAddress
- BYTE
Address
- BOOL
WriteToIC
WriteCommand
- BYTE
Command
ReadTemperatureReal
- FLOAT
Sensor Properties
Cyclic Mode
I2C Properties
| Channel selection
Address
SDA
SDA Remap Pin
SCL
SCL Remap Pin
Stop Delay
Baud Select
Threshold Output
Threshold Pin
Threshold Setting
Threshold1
| Threshold 1 Value
Threshold2
Simulate Comms
