Author
Matrix TSL
Version
1.0
Category
Comms: System
Modbus Slave (SCADA) component
Modbus component for creating Modbus compatible slave hardware via RS232 or RS485.
Please click here to download the component source project: FC_Comp_Source_Modbus_Slave_SCADA.fcsx
Please click here to view the component source code (Beta): FC_Comp_Source_Modbus_Slave_SCADA.fcsx
ReadHoldingRegister
Reads the value of a single holding register.
- UINT
Address
Coil Address
- UINT
SetCoil
Sets the state of a single digital coil.
- UINT
Address
Coil Address
- BYTE
State
0=off, 1=on
SetDigitalInput
Sets the state of a single digital input.
- UINT
Address
Coil Address
- BYTE
State
0=off, 1=on
SetSlaveAddress
Allows the slave address to be overridden from the default slave address specified in the component property. The number of bytes used for the address is fixed by the Slave ID Bytes property to save on RAM usage.
- UINT
SlaveAddress
ChangeFrameType
Default frame type is the type set in the component properties.
- BYTE
Type
0 = Modbus RTU / 1 = Modbus ASCII
ReadCoils
Reads the state of up to eight digital coils. Can pack a max of 8-bits together in a single operation
- UINT
StartAddress
Coil Address Range 0 to (NumCoils - 1)
- BYTE
AddressCount
Range 1-8
- BYTE
SetHoldingRegister
Sets the state of a single holding register.
- UINT
Address
Coil Address
- UINT
Value
Analogue Value range 0 - 65535
ReadAnalogInput
Reads the value of a single analogue input.
- UINT
Address
Coil Address
- UINT
CheckForIncoming
Checks for an incoming message and if the data address is within range then also automatically replies with the correct reply. Returns 0 if no comms received, 1 for a succesful transaction, 255 for an error.
- BYTE
ReadDigitalInputs
Reads the state of up to eight digital inputs. Can pack a max of 8-bits together in a single operation
- UINT
StartAddress
- BYTE
AddressCount
Range 1-8
- BYTE
GetLastIncoming
Gets a value from the last incoming command. Index 0 = 0 Read / 1 Write Index 1 = 0 Coils / 1 DigInput / 2 AnInput / 3 Register Index 2 = Address Index 3 = Number
- UINT
SetAnalogInput
Sets the state of a single analogue input.
- UINT
Address
Coil Address
- UINT
Value
Starts up the UART to allow communications and initialises the states of the various Modbus Coils, Inputs and Registers to 0.
Modbus Properties
Frame Type
Switches between RTU and ASCII forms of Modbus
Receive Buffer Size
Receive Timeout
Length in milliseconds to wait for additional bytes to be received when checking for incoming messages.
Slave ID Bytes
Slave Address
Reply Delay
Delay in micro seconds to wait before transmitting a reply
Maintain Stats
Controls if the last command from the master is logged allowing for easier value updates. No - Do not log commands Yes - Commands are logged and available via the GetLastIncoming macro
Runtime Properties
Console Columns
Data Source
COM Port
Lists all the current available COM port hardware on your PC.
Refresh Ports
COM port data rate in bits per second
Modbus Coils - Single bit values
Starting Address
Start address of the Modbus coils. Referenced from 0. For example Slave 1 might have 100 coils addressed 0-99 Start Address = 0 Slave 2 might have 100 coils addressed 100-199 Start Address = 100
Number of Addresses
Specifies how many Coils are available on the slave. Each address consumes a single bit of RAM, 8 Addresses are packed together into a single RAM Byte.
Digital Inputs - Single bit values
Starting Address
Start address of the Modbus digital inputs. Referenced from 0. For example Slave 1 might have 100 inputs addressed 0-99 Start Address = 0 Slave 2 might have 100 inputs addressed 100-199 Start Address = 100
Number of Addresses
Specifies how many Digital Inputs are available on the slave. Each address consumes a single bit of RAM, 8 Addresses are packed together into a single RAM Byte.
Analog Inputs - 16-bit values
Starting Address
Start address of the Modbus analogue inputs. Referenced from 0. For example Slave 1 might have 100 inputs addressed 0-99 Start Address = 0 Slave 2 might have 100 inputs addressed 100-199 Start Address = 100
Number of Addresses
Specifies how many 16-bit analogue inputs are available on the slave. Each address consumes two RAM Bytes.
Holding Registers - 16-bit values
Starting Address
Start address of the Modbus registers. Referenced from 0. For example Slave 1 might have 100 registers addressed 0-99 Start Address = 0 Slave 2 might have 100 registers addressed 100-199 Start Address = 100
Number of Addresses
Specifies how many 16-bit holding registers are available on the slave. Each address consumes two RAM Bytes.
ReadHoldingRegister
- UINT
Address
Coil Address
- UINT
SetCoil
- UINT
Address
Coil Address
- BYTE
State
0=off, 1=on
SetDigitalInput
- UINT
Address
Coil Address
- BYTE
State
0=off, 1=on
SetSlaveAddress
- UINT
SlaveAddress
ChangeFrameType
- BYTE
Type
ReadCoils
- UINT
StartAddress
- BYTE
AddressCount
Range 1-8
- BYTE
SetHoldingRegister
- UINT
Address
Coil Address
- UINT
Value
ReadAnalogInput
- UINT
Address
Coil Address
- UINT
CheckForIncoming
- BYTE
ReadDigitalInputs
- UINT
StartAddress
- BYTE
AddressCount
Range 1-8
- BYTE
GetLastIncoming
- UINT
SetAnalogInput
- UINT
Address
Coil Address
- UINT
Value
Modbus Properties
Frame Type
Receive Buffer Size
Receive Timeout
Slave ID Bytes
Slave Address
Reply Delay
Maintain Stats
Runtime Properties
Console Columns
Data Source
COM Port
Refresh Ports
Starting Address
Number of Addresses
Starting Address
Number of Addresses
Starting Address
Number of Addresses
Starting Address
Number of Addresses
ReadHoldingRegister
- UINT
Address
Coil Address
- UINT
SetCoil
- UINT
Address
Coil Address
- BYTE
State
0=off, 1=on
SetDigitalInput
- UINT
Address
Coil Address
- BYTE
State
0=off, 1=on
SetSlaveAddress
- UINT
SlaveAddress
ChangeFrameType
- BYTE
Type
ReadCoils
- UINT
StartAddress
- BYTE
AddressCount
Range 1-8
- BYTE
SetHoldingRegister
- UINT
Address
Coil Address
- UINT
Value
ReadAnalogInput
- UINT
Address
Coil Address
- UINT
CheckForIncoming
- BYTE
ReadDigitalInputs
- UINT
StartAddress
- BYTE
AddressCount
Range 1-8
- BYTE
GetLastIncoming
- UINT
SetAnalogInput
- UINT
Address
Coil Address
- UINT
Value
Modbus Properties
Frame Type
Receive Buffer Size
Receive Timeout
Slave ID Bytes
Slave Address
Reply Delay
Maintain Stats
Runtime Properties
Console Columns
Data Source
COM Port
Refresh Ports
Starting Address
Number of Addresses
Starting Address
Number of Addresses
Starting Address
Number of Addresses
Starting Address
Number of Addresses
ReadHoldingRegister
- UINT
Address
Coil Address
- UINT
SetCoil
- UINT
Address
Coil Address
- BYTE
State
0=off, 1=on
SetDigitalInput
- UINT
Address
Coil Address
- BYTE
State
0=off, 1=on
SetSlaveAddress
- UINT
SlaveAddress
ChangeFrameType
- BYTE
Type
ReadCoils
- UINT
StartAddress
- BYTE
AddressCount
Range 1-8
- BYTE
SetHoldingRegister
- UINT
Address
Coil Address
- UINT
Value
ReadAnalogInput
- UINT
Address
Coil Address
- UINT
CheckForIncoming
- BYTE
ReadDigitalInputs
- UINT
StartAddress
- BYTE
AddressCount
Range 1-8
- BYTE
GetLastIncoming
- UINT
SetAnalogInput
- UINT
Address
Coil Address
- UINT
Value
Modbus Properties
Frame Type
Receive Buffer Size
Receive Timeout
Slave ID Bytes
Slave Address
Reply Delay
Maintain Stats
Runtime Properties
Console Columns
Data Source
COM Port
Refresh Ports
Starting Address
Number of Addresses
Starting Address
Number of Addresses
Starting Address
Number of Addresses
Starting Address
Number of Addresses
