Component: DC Motor ()
Revision as of 09:59, 27 January 2023 by Wiki bot (talk | contribs)
Author Matrix Ltd.
Version 1.2
Category
DC Motor component
DC Motor that can be driven in one or both directions using digital output pins, PWM or HBRIDGE peripherals.
Please click here to download the component source project: FC_Comp_Source_Motor_with_reverse.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Motor_with_reverse.fcfx
Simple example showing how to drive the motor components and how to create sub assemblies attached to the motor output shafts in the simulation panels. Motors
Coast
Turn off power to the motor by setting the pins according to the 'Coast Pattern' property.
Break
Actively drives both ends of the motor by setting the pins according to the 'Brake Pattern' property.
Disable
Disable the motor output
Forwards
Set the motor turning in the forwards direction by setting the pins according to the 'Reverse Pattern' property.
- UINT Duty
Sets the motor power for PWM or H-Bridge outputs
Enable
Enables the motor output
Reverse
Set the motor turning in the reverse direction by setting the pins according to the 'Reverse Pattern' property.
- UINT Duty
Control Type
Control Method
Controls how the motor is controlled. On/Off requires output pins PWM requires a hardware PWM channel H-Bridge requires a hardware H-Bridge channel
Bridge Type
Enable Method
Decides how the motor outputs are enabled.
PinA
First control pin - set 'pattern' properties below to set the pin's function.
PinB
Second control pin - set 'pattern' properties below to set the pin's function.
Forwards Pattern
The state of pins A and B required to drive the motor in a forwards direction.
Reverse Pattern
States of pins A and B required to drive the motor in a reverse direction.
Coast Pattern
States of pins A and B required to stop the motor.
Brake Pattern
Simulation Settings
Speed
Speed of the motor when turned on. Positive speed -> Counter-clockwsie Negative speed -> Clockwise
Acceleration
Speed change per second when the motor us powered. Set to zero for instantaneous speed changes.
Deceleration
Speed change per second when the motor is coasting with no power. Set to zero for instantaneous speed changes.
Show Actuator
When active, an actuator is shown on the motor spindle to make the animation easier to observe.
Forwards Direction
Which way the motor will rotate when the 'forwards' command is sent.
Linkage
Target Object
An object or group to link the motor to - the object will move along with the motor.
Coast
Break
Disable
Forwards
- UINT Duty
Enable
Reverse
- UINT Duty
Control Type
Control Method
Bridge Type
Enable Method
PinA
PinB
Forwards Pattern
Reverse Pattern
Coast Pattern
Brake Pattern
Simulation Settings
Speed
Acceleration
Deceleration
Show Actuator
Forwards Direction
Linkage
Target Object
Coast
Break
Disable
Forwards
- UINT Duty
Enable
Reverse
- UINT Duty
Control Type
Control Method
Bridge Type
Enable Method
PinA
PinB
Forwards Pattern
Reverse Pattern
Coast Pattern
Brake Pattern
Simulation Settings
Speed
Acceleration
Deceleration
Show Actuator
Forwards Direction
Linkage
Target Object
Coast
Break
Disable
Forwards
- UINT Duty
Enable
Reverse
- UINT Duty
Control Type
Control Method
Bridge Type
Enable Method
PinA
PinB
Forwards Pattern
Reverse Pattern
Coast Pattern
Brake Pattern
Simulation Settings
Speed
Acceleration
Deceleration
Show Actuator
Forwards Direction
Linkage
Target Object
