| Author
Matrix Ltd.
| Version
2.0
| Category
Wireless
RF ISM (EB063, MRF49XA) component
A simple RF-ISM communications module based on the Microchip Alpha MRF49XA device. Also available in the form of the EB063 RF E-block.
Please click here to download the component source project: FC_Comp_Source_RF-ISM.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_RF-ISM.fcfx
The example attempts to send and receive data from a remote board. You will need two RF modules to allow the communications to work.
The example can be used to drive both ends of the RF communications as it will send out data but also print out any data received onto the LCD. Pins RA0 and RA1 can be used for diagnostics on the program.
RF Example
SetSyncPattern
| Allows the sync pattern to be modified during runtime to allow for switching between several different RF connections.
- BYTE
Mode
| Switches on or off the extended sync functionality
- BYTE
Pattern
| The bit pattern used for the standard sync mode
ReceiveByte
| Puts the RF module in data mode and attempts to receive a single byte from the RF connection. Only packets containing a single data byte will be accepted.
- BYTE
Timeout
| Specifies how many milliseconds to wait for valid data before returning.
- BYTE
SendString
| Puts the RF module in data mode and transmits a packet containing the data string through the RF connection. A packet consists of Sync information, Data and Checksum.
- STRING
Data
TXTune
| Used to specify and adjust the RF transmitter properties during runtime.
- BYTE
Deviation
| Specifies the transmit FSK frequency deviation - Range 0 - 15
- BYTE
Power
| Specifies the transmitter power - Range 0 - 7
RXTune
| Used to specify and adjust the RF receiver properties during runtime.
- BYTE
Bandwidth
| Specifies the Rx bandwidth - Range 1- 6
- BYTE
Gain
| Specifies the Rx gain - Range 0 - 3
- BYTE
Threshold
| Specifies the Rx signal to noise threshold - Range 0 - 5
SetBufferData
| Allows a value to be loaded into the transmit buffer,
- BYTE
Index
| The current location in the transmit buffer starting from 0
- BYTE
Data
| The data value to pass
UpdateCenterFrequency
| Allows the RF center frequency to be adjusted during runtime to allow multiple RF channels to be scanned or multiplexed.
- UINT
Frequency
| Specifies the new center frequency value - Range 96 - 3903
FSKWrite
| Writes to the FSK (frequency shift key) data pin.
- BYTE
State
GetDataCount
| Returns the number of bytes in the received data buffer.
- BYTE
SendBuffer
| Sends the contents of the transmit buffer.
- BYTE
Count
| Specifies how many bytes to transfer from the transmit buffer
SendByte
| Puts the RF module in data mode and transmits a packet containing a single data byte through the RF connection. A packet consists of Sync information, Data and Checksum.
- BYTE
Data
ActivateTXMode
| Enables the transmitter interface, allowing data to be sent. The receiver interface is automatically disabled.
SetDataRate
| Allows the RF data rate to be adjusted during runtime.
- BYTE
Rate
| Specifies the new data rate
ActivateRXMode
| Enables the receiver interface, allowing data to be received. The transmitter interface is automatically disabled.
FSKRead
| Reads the FSK (frequency shift key) data pin.
- BYTE
ReadRXSignalStrength
| Returns the current received signal strength.
- BYTE
Uninitialise
| Powers down the RF module. The module must be re-initialised before it can be used again.
CheckBuffer
| Checks for incoming data for a specific period of time. Returns a value greater then 250 to indicate a failure. Returns the length of the incoming data buffer to indicate success.
- BYTE
Timeout
| Time to wait before returning no data available
- BYTE
GetBufferData
| Returns a value from the incoming receive data buffer.
- BYTE
Index
| Specifies which position in the buffer to read data from
- BYTE
ReceiveString
| Puts the RF module in data mode and attempts to receive a string of bytes from the RF connection.
- BYTE
Length
| Specifies the maximum number of bytes to try and receive
- BYTE
Timeout
- STRING
| Starts up and configures the RF module ready for use. The macro will return a value greater then 0 if the module has been started correctly, otherwise the macro will return a 0.
- BYTE
| SPI Channel selector
MOSI
MISO
CLK
CS / SS
| Chip Select / Slave Select Pin Master Mode: General purpose output pin used to select the remote SPI device. Slave Mode: Hardware chip select pin input used to select the SPI device.
FSEL Pin
| RF Mode selection pin
RF Settings
Module Frequency
| Module frequency - must be matched with the specific RF transciever being used.
Center Frequency (96-3903)
| Specifies the default RF center frequency
Center Frequency (MHz)
| Calculation to work out the approx actual frequency
Data Mode
| Specifies if the module will send data packets (Byte) or FSK bits (Bit)
Data Buffer Size (Max)
| Maximum number of bytes that can be loaded into a single data packet
Rate Divider 1
| Data rate prescaler 1 - Coarse control
Rate Divider 2 (0-127)
| Data rate prescaler 2 - Fine control
Max Throughput (Kb/s)
| Calculated max data throughput if the data is 100% active
Data Rate Value
| Actual default value passed to the data rate control
Sync Pattern
| Default sync pattern used by the standard sync in byte data mode.
Extended Sync
| Selects if an additional fixed sync byte is to be used.
Receiver Settings
Bandwidth
| Controls the receiver bandwidth, the higher the value the bigger the datarate that can be acheived but the fewer channels that can co-exist
Gain
| Controls the receiver gain - the amount to amplify the incoming signal before processing
Threshold
| The signal to noise threshold used to control the sensitivity
Transmitter Settings
Bandwidth
| Controls the transmitter bandwidth, i.e. the frequency either side of the center frequency to use for the RF communications
Power
| The amount of power to use when transmitting
| Label used to help identify the component on the panel.
API
SetSyncPattern
- BYTE
Mode
- BYTE
Pattern
ReceiveByte
- BYTE
Timeout
- BYTE
SendString
- STRING
Data
TXTune
- BYTE
Deviation
- BYTE
Power
RXTune
- BYTE
Bandwidth
- BYTE
Gain
- BYTE
Threshold
SetBufferData
- BYTE
Index
- BYTE
Data
- UINT
Frequency
FSKWrite
- BYTE
State
GetDataCount
- BYTE
SendBuffer
- BYTE
Count
SendByte
- BYTE
Data
ActivateTXMode
SetDataRate
- BYTE
Rate
ActivateRXMode
FSKRead
- BYTE
- BYTE
Uninitialise
CheckBuffer
- BYTE
Timeout
- BYTE
GetBufferData
- BYTE
Index
- BYTE
ReceiveString
- BYTE
Length
- BYTE
Timeout
- STRING
- BYTE
MOSI
MISO
CLK
CS / SS
FSEL Pin
RF Settings
Module Frequency
Data Mode
Rate Divider 1
Data Rate Value
Sync Pattern
Extended Sync
Receiver Settings
Bandwidth
Gain
Threshold
Bandwidth
Power
API
SetSyncPattern
- BYTE
Mode
- BYTE
Pattern
ReceiveByte
- BYTE
Timeout
- BYTE
SendString
- STRING
Data
TXTune
- BYTE
Deviation
- BYTE
Power
RXTune
- BYTE
Bandwidth
- BYTE
Gain
- BYTE
Threshold
SetBufferData
- BYTE
Index
- BYTE
Data
- UINT
Frequency
FSKWrite
- BYTE
State
GetDataCount
- BYTE
SendBuffer
- BYTE
Count
SendByte
- BYTE
Data
ActivateTXMode
SetDataRate
- BYTE
Rate
ActivateRXMode
FSKRead
- BYTE
- BYTE
Uninitialise
CheckBuffer
- BYTE
Timeout
- BYTE
GetBufferData
- BYTE
Index
- BYTE
ReceiveString
- BYTE
Length
- BYTE
Timeout
- STRING
- BYTE
MOSI
MISO
CLK
CS / SS
FSEL Pin
RF Settings
Module Frequency
Data Mode
Rate Divider 1
Data Rate Value
Sync Pattern
Extended Sync
Receiver Settings
Bandwidth
Gain
Threshold
Bandwidth
Power
API
SetSyncPattern
- BYTE
Mode
- BYTE
Pattern
ReceiveByte
- BYTE
Timeout
- BYTE
SendString
- STRING
Data
TXTune
- BYTE
Deviation
- BYTE
Power
RXTune
- BYTE
Bandwidth
- BYTE
Gain
- BYTE
Threshold
SetBufferData
- BYTE
Index
- BYTE
Data
- UINT
Frequency
FSKWrite
- BYTE
State
GetDataCount
- BYTE
SendBuffer
- BYTE
Count
SendByte
- BYTE
Data
ActivateTXMode
SetDataRate
- BYTE
Rate
ActivateRXMode
FSKRead
- BYTE
- BYTE
Uninitialise
CheckBuffer
- BYTE
Timeout
- BYTE
GetBufferData
- BYTE
Index
- BYTE
ReceiveString
- BYTE
Length
- BYTE
Timeout
- STRING
- BYTE
MOSI
MISO
CLK
CS / SS
FSEL Pin
RF Settings
Module Frequency
Data Mode
Rate Divider 1
Data Rate Value
Sync Pattern
Extended Sync
Receiver Settings
Bandwidth
Gain
Threshold
Bandwidth
Power
API
