Component: Serial Flash (W25) (EEPROM)
Revision as of 09:59, 27 January 2023 by Wiki bot (talk | contribs)
Category EEPROM
Serial Flash (W25) component
Component to allow support for the Winbond W25 range of SPI Flash devices. Compatible with various sizes of Flash including: 2Mb, 4Mb, 8Mb, 32Mb, 64Mb, 128Mb.
Please click here to download the component source project: FC_Comp_Source_SerialFlash_W25Q.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_SerialFlash_W25Q.fcfx
WriteControl
Enables or disables writing for things like erasing and programming. Writes must be enabled after a power on reset and again after an erase command.
- BOOL Status
1 = Write Enabled, 0 = Write Protected
ReadStatus
Reads one of the internal status registers on the device
- BYTE Reg
Selects which status register to read, 0 = Status or 1 = Status 2.
ReadDataByte
Reads a single data byte from the specified address.
- UINT PageAddress
Address bits A23-A8 : 16-bit Address - Range 0x0000 - 0xFFFF
- BYTE ByteAddress
A7-A0 : 8-bit Address within the page - Range 0x00 - 0xFF
ReadUniqueID
Reads the 8-byte unique identifier from the IC. Useful if you need each board to have it's own guarenteed unique address or identifier.
- BYTE ID
8-Byte data array to store the unique ID read back from the IC.
WriteDataArray
Writes an array of data bytes atarting at the specified address. Writes must be enabled and memory locations must be erased for data writes to function correctly. Note that all bytes will be written to the same page.
- UINT PageAddress
- BYTE ByteAddress
- BYTE Count
Number of bytes to write.
- BYTE Data
EraseChip
Erases all data stored on the chip. Chip erase takes between 20 seconds and 100 seconds to complete. Blocking mode is recommended to ensure write cycle is complete.
- BOOL Blocking
Controls if the macro blocks until the erase cycle is complete. 0 = Don't Wait, 1 = Wait
WriteDataByte
Writes a single data byte to the specified address. Writes must be enabled and memory locations must be erased for data writes to function correctly.
- UINT PageAddress
- BYTE ByteAddress
- BYTE Data
Data byte to write
EraseBlock
Erases a block of data stored on the chip. Erase takes between 45 milliseconds and 2000 milliseconds to complete. Blocking mode is recommended to ensure write cycle is complete.
- BYTE EraseMode
0=4KB / 1=32KB / 2=64KB
- UINT PageAddress
- BOOL Blocking
ReadDataArray
Reads up to 256 data bytes starting from the specified address. Note that all bytes will be read from the same page.
- UINT PageAddress
- BYTE ByteAddress
- BYTE Count
Number of bytes to read.
- BYTE Data
Byta array to store the incoming read data.
Initialises the SPI bus ready for communications.
Flash Properties
Memory Size
Sets the size of the flash memory available on the chip.
Number Bytes
Number Pages
SPI Properties
SPI Channel selector
Prescale
Prescale option selector
MOSI
MISO
CLK
CS / SS
Simulate Comms
Decides how the simulation handles the data. No - Do no SPI simulation and allow all simulation data to come from a local text file. Yes - Use SPI simulation for use with Injector components etc.
File Simulation
Simulation File
Name of file to use to hold the contents of the simulated flash memory. $(srcdir) assigns the file to the same folder as the Flowcode project file.
Unique ID Lower 32-bit
Unique ID Upper 32-bit
WriteControl
- BOOL Status
ReadStatus
- BYTE Reg
ReadDataByte
- UINT PageAddress
- BYTE ByteAddress
ReadUniqueID
- BYTE ID
WriteDataArray
- UINT PageAddress
- BYTE ByteAddress
- BYTE Count
- BYTE Data
EraseChip
- BOOL Blocking
WriteDataByte
- UINT PageAddress
- BYTE ByteAddress
- BYTE Data
Data byte to write
EraseBlock
- BYTE EraseMode
- UINT PageAddress
- BOOL Blocking
ReadDataArray
- UINT PageAddress
- BYTE ByteAddress
- BYTE Count
- BYTE Data
Flash Properties
Memory Size
Number Bytes
Number Pages
SPI Properties
Prescale
MOSI
MISO
CLK
CS / SS
Simulate Comms
File Simulation
Simulation File
WriteControl
- BOOL Status
ReadStatus
- BYTE Reg
ReadDataByte
- UINT PageAddress
- BYTE ByteAddress
ReadUniqueID
- BYTE ID
WriteDataArray
- UINT PageAddress
- BYTE ByteAddress
- BYTE Count
- BYTE Data
EraseChip
- BOOL Blocking
WriteDataByte
- UINT PageAddress
- BYTE ByteAddress
- BYTE Data
Data byte to write
EraseBlock
- BYTE EraseMode
- UINT PageAddress
- BOOL Blocking
ReadDataArray
- UINT PageAddress
- BYTE ByteAddress
- BYTE Count
- BYTE Data
Flash Properties
Memory Size
Number Bytes
Number Pages
SPI Properties
Prescale
MOSI
MISO
CLK
CS / SS
Simulate Comms
File Simulation
Simulation File
WriteControl
- BOOL Status
ReadStatus
- BYTE Reg
ReadDataByte
- UINT PageAddress
- BYTE ByteAddress
ReadUniqueID
- BYTE ID
WriteDataArray
- UINT PageAddress
- BYTE ByteAddress
- BYTE Count
- BYTE Data
EraseChip
- BOOL Blocking
WriteDataByte
- UINT PageAddress
- BYTE ByteAddress
- BYTE Data
Data byte to write
EraseBlock
- BYTE EraseMode
- UINT PageAddress
- BOOL Blocking
ReadDataArray
- UINT PageAddress
- BYTE ByteAddress
- BYTE Count
- BYTE Data
Flash Properties
Memory Size
Number Bytes
Number Pages
SPI Properties
Prescale
MOSI
MISO
CLK
CS / SS
Simulate Comms
File Simulation
Simulation File
