Component: 7Segment (Hex TM1637) 2D (Segment)
Revision as of 10:00, 27 January 2023 by Wiki bot (talk | contribs)
Category Segment
7Segment (Hex TM1637) 2D component
Hex seven segment display using an two pin communications bus to reduce the number of control pins. Also provides up to 16 individual input switches. Driven using a TM1637 hex 7-segment display driver.
Please click here to download the component source project: FC_Comp_Source_TM1637_7SEG_Hex_Driver_2dgi.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_TM1637_7SEG_Hex_Driver_2dgi.fcfx
Fc9-comp-macro.png ShowDigits
Set the number and decimal point to be displayed in the given digit of the display.
Fc9-u8-icon.png - BYTE Value0
The number value to set the digit to (0...15), 16=Clear
Fc9-u8-icon.png - BYTE Value1
Fc9-u8-icon.png - BYTE Value2
Fc9-u8-icon.png - BYTE Value3
Fc9-u8-icon.png - BYTE Value4
Fc9-u8-icon.png - BYTE Value5
Fc9-u8-icon.png - BYTE DecimalPoint
Bit field containing the states of the decimal points.
Fc9-comp-macro.png ReadSwitches
Samples the switches and returns a value from 0-16. 0 indicates that no switches are pressed. 1 - 16 indicates that a switch is pressed and provides the index of the switch. Only one switch can be pressed at any time.
Fc9-comp-macro.png SetBrightness
Controls the brightness of the 7-seg displays
Fc9-u8-icon.png - BYTE Brightness
Range: 0-7 - 0=Darkest, 7=Brightest
Fc9-bool-icon.png - BOOL On
0 = Display Off, 1 = Display On
Fc9-comp-macro.png ShowSegments
Allows for manual control over the display segments. The colon character can also be controlled when writing to digit 1.
Fc9-u8-icon.png - BYTE Digit
Which of the digits to change. (0...5)
Fc9-u8-icon.png - BYTE Segments
The binary segment value to display
Set the number to be displayed in the given digit of the display. The colon character can also be controlled when writing to digit 1.
Whether to show the decimal point.
Fc9-type-16-icon.png Display Type
Set this according to the specification of your hardware display. Common Anode: Pin true -> LED Off, Pin false -> LED On Common Cathode: Pin true -> LED On, Pin false -> LED Off
Fc9-type-7-icon.png Show Seg Labels
Show segment name labels overlayed over the component.
Fc9-type-5-icon.png DIO
Data Pin connection to TM1637 IC
Fc9-type-5-icon.png CLK
Clock Pin connection to TM1637 IC
Fc9-conn-icon.png Colors
Fc9-type-1-icon.png LED Color
Color of the LED segments when truned on. When off, they use a much darker shade of the same hue.
Fc9-type-1-icon.png Body Color
Color of the plastic casing containing the LEDs.
Fc9-type-1-icon.png Label Color
Color for the optional LED segment labels.
