Component: Touch Screen (XPT2046) (Graphical Library)
Revision as of 10:00, 27 January 2023 by Wiki bot (talk | contribs)
Version 2.0
Category Graphical Library
Touch Screen (XPT2046) component
Low level routines for controlling or interacting with the XPT2046 touch screen controller IC found on a lot of common low cost resistive touch screen products.
Please click here to download the component source project: FC_Comp_Source_TouchScreen_XPT2046.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_TouchScreen_XPT2046.fcfx
Example using the XPT2046 touchscreen driver IC with a 4.3" TFT Display using the SSD1963 Graphical LCD Controller. FC6 Icon.png GLCD 4.3 Touch Example using the XPT2046 touchscreen driver IC with a 7" TFT Display using the SSD1963 Graphical LCD Controller. FC6 Icon.png GLCD 7 Touch
Fc9-comp-macro.png SampleSensor
Reads the touch controller and returns true if there is currently a touch in progress. The touch coordinates can be read using the ReadCoord macro. Return 0 = No Touch, 1 = Touch in progress
Fc9-comp-macro.png ReadCoord
Reads a coordinate returned from the Sample Sensor macro. Coordinate is scaled to the X/Y Pixel bounds specified.
Fc9-u8-icon.png - BYTE Coordinate
0 = X, 1 = Y, 2 = Pressure
Fc9-comp-macro.png Initialise
Activates the SPI peripheral and claims control over the I/O pins.
Fc9-type-16-icon.png LinkTo
Fc9-conn-icon.png Bus Settings
Fc9-type-16-icon.png Channel
SPI Channel selector
Fc9-type-16-icon.png Prescale
Prescale option selector
Fc9-type-5-icon.png MOSI
Fc9-type-5-icon.png MISO
Fc9-type-5-icon.png CLK
Fc9-type-5-icon.png CS / SS
Fc9-conn-icon.png Configuration
Fc9-type-16-icon.png Analogue Mode
Fc9-type-21-icon.png X Pixel
Fc9-type-21-icon.png Y Pixel
Fc9-type-7-icon.png Flip X
Fc9-type-7-icon.png Flip Y
Fc9-conn-icon.png Simulation
Fc9-type-10-icon.png Label
Label used to identify the component on the panel.
Fc9-type-7-icon.png Enable Interrupt
Allows the simulated display to fire an interrupt to allow you to action inputs as they happen.
Fc9-type-22-icon.png Interrupt Macro
Macro called when the simulated display fires an interrupt.
Allows the SPI communications to be simulated and piped through an API to real world hardware.
