| Author
Matrix TSL
| Version
2.2
| Category
Misc
UART component
CAL = Code Abstraction Layer - Allows one code base to run on a wide range of chips. A low level implementation giving direct access to the UART peripheral. Includes simulation functionality to commmunicate via a COM port or an Injector component. Also includes timestamped logging via the console and Data Recorder trace monitoring support.
Please click here to download the component source project: FC_Comp_Source_UART.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_UART.fcfx
ControlPin
| Allows direct control over the TX and RTS pins Also allows for reading of the state of the RX and CTS pins. Only available when the UART is uninitialised.
- BYTE
Pin
| 0=TX, 1=RX, 2=RTS, 3=CTS
- BYTE
State
- BYTE
SendString
| Transmits a string of bytes via the UART peripheral
- STRING
Data
| Data String to transmit
UpdateBaud
| Changes the UART Baud rate. 0=1200, 1=2400, 2=4800, 3=9600, 4=19200, 5=38400, 6=57600, 7=115200, 8=250000
- BYTE
new_baud
TestProperty
| A simple macro to allow us to test the value of a single property during runtime.
- BYTE
Property
| 0=UseTX, 1=UseRX, 2=UseFlowControl
- BYTE
SendNumber
| Transmits a numeric value as an ASCII string
- LONG
Number
| Numeric value to send
GetValue
| Get Value of Named property
- STRING
Name
- STRING
Prv_SimShowWaveform
- BYTE
TXRX
- UINT
Data
Receive
| Receive a Character
- BYTE
Timeout
| Period to wait for the character to be received
- INT
Send
| Send the Character
- UINT
Char
| The Character to send
GetConsoleHandle
- HANDLE
SendByteArray
| Transmits an array of bytes via the UART peripheral
- BYTE
Data
| Data to transmit
- BYTE
NumBytes
| Number of bytes to send from the array
Init
| Initialize the component with the specified properties
Delay
| Software UART Bit Delay
SetValue
| set Value of Named property
- STRING
Name
- STRING
Value
Uninit
| Un-initialize the UART and release the resources
GetList
| Gets Named property List
- STRING
Name
- STRING
ReceiveByteArray
| Receives an array of bytes and returns the number of bytes received.
- BYTE
Data
- BYTE
NumBytes
| Maximum number of bytes to try and receive
- BYTE
Timeout
| Max amount of time in ms to wait between bytes
- BYTE
ReceiveString
| Receives a string of bytes and returns the number of bytes received.
- STRING
StringData
- BYTE
NumBytes
- BYTE
Timeout
- BYTE
Component Enable
| A global flag to enable or disable the UART component from producing code. Useful for generating components with multiple communications options.
| UART Channel selector Software channels are bit banged using generic I/O pins but are not as reliable as hardware channels. Hardware channels use the selected peripheral on-board the target microcontroller.
Transmit
Use TX
| Selects if the Transmit pin is used by the component. Yes: The TX pin is active and used to transmit data for the UART. No: The TX pin is disabled and free to be used as general I/O.
TX
| Pin to be used for Transmit data
Receive
Use RX
| Selects if the Receive pin is used by the component. Yes: The RX pin is active and used to receive data for the UART. No: The RX pin is disabled and free to be used as general I/O.
RX
| Pin to be used for Receive data
Flow Control
Use Flow Control
| Flow Control (Handshake) enable or disable. On: Two I/O pins are used to control the flow of data in and out of the device. Off: Flow control is disabled.
Options
Baud Options
| Baud rate option selector
Data Bits
| Number of data bits
| Return data width from Receive macro. 8-bit data mode always returns a byte ranging from 0-255, 255 could mean a timeout or could be a valid data. 16-bit data mode rereturns 0-255 for valid data, 256 for a timeout, return data must be stored into an INT or UINT variable.
Echo
| Automatically echoes back any received data when enabled by re-transmitting the received byte.
Interrupt
| Automatic receive interrupt mode enable or disable. Used on components such as the GSM or GPS where data can come in at any time. Software channel is disabled when interrupt is enabled, for interrupt with a software channel use an I/O edge triggered interrupt.
| Selects if the scope traces are automatically added to the data recorder window or not. Simulation - draws an approximation of the UART data onto the scope trace. ICT - sets up the scope trace for incoming data and adds UART packet decoding at the correct BAUD.
Console Format
| Controls if the data is shown as a log with time and date stamps or just as raw data
Console Columns
| Number of characters that can be displayed on a single line of the console.
Data Source
| Simulation data source used to allow the component to connect to various remote devices Nothing - Simulation data is ignored COM port - Routes the communication data to and from a physical or virtual COM port API - Routes the communication data via a data injector component on the Panel.
ControlPin
- BYTE
Pin
- BYTE
State
- BYTE
SendString
- STRING
Data
UpdateBaud
- BYTE
new_baud
TestProperty
- BYTE
Property
- BYTE
SendNumber
- LONG
Number
GetValue
- STRING
Name
- STRING
Prv_SimShowWaveform
- BYTE
TXRX
- UINT
Data
Receive
| Receive a Character
- BYTE
Timeout
- INT
Send
| Send the Character
- UINT
Char
GetConsoleHandle
- HANDLE
SendByteArray
- BYTE
Data
| Data to transmit
- BYTE
NumBytes
Init
Delay
SetValue
- STRING
Name
- STRING
Value
Uninit
GetList
- STRING
Name
- STRING
ReceiveByteArray
- BYTE
Data
- BYTE
NumBytes
- BYTE
Timeout
- BYTE
ReceiveString
- STRING
StringData
- BYTE
NumBytes
- BYTE
Timeout
- BYTE
Component Enable
Transmit
Use TX
TX
Receive
Use RX
RX
Flow Control
Use Flow Control
Options
Baud Options
Data Bits
| Number of data bits
Echo
Interrupt
Console Format
Console Columns
Data Source
ControlPin
- BYTE
Pin
- BYTE
State
- BYTE
SendString
- STRING
Data
UpdateBaud
- BYTE
new_baud
TestProperty
- BYTE
Property
- BYTE
SendNumber
- LONG
Number
GetValue
- STRING
Name
- STRING
Prv_SimShowWaveform
- BYTE
TXRX
- UINT
Data
Receive
| Receive a Character
- BYTE
Timeout
- INT
Send
| Send the Character
- UINT
Char
GetConsoleHandle
- HANDLE
SendByteArray
- BYTE
Data
| Data to transmit
- BYTE
NumBytes
Init
Delay
SetValue
- STRING
Name
- STRING
Value
Uninit
GetList
- STRING
Name
- STRING
ReceiveByteArray
- BYTE
Data
- BYTE
NumBytes
- BYTE
Timeout
- BYTE
ReceiveString
- STRING
StringData
- BYTE
NumBytes
- BYTE
Timeout
- BYTE
Component Enable
Transmit
Use TX
TX
Receive
Use RX
RX
Flow Control
Use Flow Control
Options
Baud Options
Data Bits
| Number of data bits
Echo
Interrupt
Console Format
Console Columns
Data Source
ControlPin
- BYTE
Pin
- BYTE
State
- BYTE
SendString
- STRING
Data
UpdateBaud
- BYTE
new_baud
TestProperty
- BYTE
Property
- BYTE
SendNumber
- LONG
Number
GetValue
- STRING
Name
- STRING
Prv_SimShowWaveform
- BYTE
TXRX
- UINT
Data
Receive
| Receive a Character
- BYTE
Timeout
- INT
Send
| Send the Character
- UINT
Char
GetConsoleHandle
- HANDLE
SendByteArray
- BYTE
Data
| Data to transmit
- BYTE
NumBytes
Init
Delay
SetValue
- STRING
Name
- STRING
Value
Uninit
GetList
- STRING
Name
- STRING
ReceiveByteArray
- BYTE
Data
- BYTE
NumBytes
- BYTE
Timeout
- BYTE
ReceiveString
- STRING
StringData
- BYTE
NumBytes
- BYTE
Timeout
- BYTE
Component Enable
Transmit
Use TX
TX
Receive
Use RX
RX
Flow Control
Use Flow Control
Options
Baud Options
Data Bits
| Number of data bits
Echo
Interrupt
Console Format
Console Columns
Data Source
