| Author
Matrix Ltd.
| Version
2.4
| Category
Comms: Networking
WLAN (ESP32) component
Wireless LAN component designed to work with ESP32 modules
Please click here to download the component source project: FC_Comp_Source_WLAN_ESP32.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_WLAN_ESP32.fcfx
ReadIPString
| Collects the local IP address and returns it as an ASCII string. e.g. "192.168.0.1"
- STRING
SocketConnect
- STRING
Address
- UINT
Port
- BYTE
SocketListen
| Listen on, or bind, local port to already opened socket. Returns 1 if OK, 0 if fail
- UINT
Port
- BYTE
ReadSSIDFromScan
| Collects one of the SSID name strings from the last SSID Scan. The ScanForSSID macro must be called first.
- BYTE
Index
| SSID Index
- STRING
CreateAccessPoint
| Sets up the wireless LAN module into AP mode to host a wireless network. Other WIFI enabled devices can then connect to the module. Returns 1 for success.
- STRING
SSID
| Name of the wireless network to create
- STRING
Password
| Password used to gain access to the network
- BYTE
| 802.11 Channel Range 1-14
- BYTE
Encryption
| 0=Open, 1=WEP, 2=WPA_PSK, 3=WPA2_PSK, 4=WPA_WPA2_PSK
- BYTE
ReadIP
| Collects a single byte from the local IP address. For example 192.168.0.1 Index = 3 : Return = 192 / Index = 0 : Return = 1
- BYTE
Index
| Range: 0 to 3 Where 3 = the first number and 0 = the last number
- BYTE
SocketWrite
- STRING
Buffer
- UINT
Size
- UINT
Disconnect
| Attempts to disconnect from the SSID.
- BYTE
ReadSignalStrengthFromScan
| Collects the signal strength from the last SSID Scan. The ScanForSSID macro must be called first. Value returned is in negative dB, smaller value = better signal
- BYTE
Index
| SSID Index
- INT
ReadEncryptionModeFromScan
| Collects one of the encryption modes from the last SSID Scan. The ScanForSSID macro must be called first. 0=Open, 1=WEP, 2=WPA_PSK, 3=WPA2_PSK, 4=WPA_WPA2_PSK
- BYTE
Index
| SSID Index
- BYTE
ConnectToSSID
| Attempts to connect to the given SSID and Key values. Returns 1 if the SSID has been connected.
- STRING
SSID
- STRING
Key
- BYTE
Timeout
| Number of seconds to wait for the connection, default 20
- BYTE
SocketOpen
| Returns 1 if socket sucessfully opened
- BYTE
SocketClose
Uninitialise
| Shuts down the WiFi system for low power operation. Returns 1 if successful Returns 0 if not
- BYTE
AcceptOpen
| Returns 1 if there is an incoming connection on the listening port
- BYTE
ScanForSSID
| Checks for wireless networks in the local area which are broadcasting their SSID. Must not be connected to a network to allow this to function. Returns the number of wireless networks found, max 8.
- BYTE
SocketRead
- STRING
Buffer
- UINT
Size
- UINT
AcceptClose
| Close the socket associated with the Accepted incoming connection
| Initialise the WiFi system Returns 1 if successful Returns 0 if not
- BYTE
Verbose Debug
Network Interface
| List of network interfaces connected to the PC. Sets which interface we are communicating via.
| Generate Console Data
ReadIPString
- STRING
SocketConnect
- STRING
Address
- UINT
Port
- BYTE
SocketListen
- UINT
Port
- BYTE
ReadSSIDFromScan
- BYTE
Index
| SSID Index
- STRING
CreateAccessPoint
- STRING
SSID
- STRING
Password
- BYTE
- BYTE
Encryption
- BYTE
ReadIP
- BYTE
Index
- BYTE
SocketWrite
- STRING
Buffer
- UINT
Size
- UINT
Disconnect
- BYTE
- BYTE
Index
| SSID Index
- INT
- BYTE
Index
| SSID Index
- BYTE
ConnectToSSID
- STRING
SSID
- STRING
Key
- BYTE
Timeout
- BYTE
SocketOpen
- BYTE
SocketClose
Uninitialise
- BYTE
AcceptOpen
- BYTE
ScanForSSID
- BYTE
SocketRead
- STRING
Buffer
- UINT
Size
- UINT
AcceptClose
- BYTE
Verbose Debug
Network Interface
ReadIPString
- STRING
SocketConnect
- STRING
Address
- UINT
Port
- BYTE
SocketListen
- UINT
Port
- BYTE
ReadSSIDFromScan
- BYTE
Index
| SSID Index
- STRING
CreateAccessPoint
- STRING
SSID
- STRING
Password
- BYTE
- BYTE
Encryption
- BYTE
ReadIP
- BYTE
Index
- BYTE
SocketWrite
- STRING
Buffer
- UINT
Size
- UINT
Disconnect
- BYTE
- BYTE
Index
| SSID Index
- INT
- BYTE
Index
| SSID Index
- BYTE
ConnectToSSID
- STRING
SSID
- STRING
Key
- BYTE
Timeout
- BYTE
SocketOpen
- BYTE
SocketClose
Uninitialise
- BYTE
AcceptOpen
- BYTE
ScanForSSID
- BYTE
SocketRead
- STRING
Buffer
- UINT
Size
- UINT
AcceptClose
- BYTE
Verbose Debug
Network Interface
ReadIPString
- STRING
SocketConnect
- STRING
Address
- UINT
Port
- BYTE
SocketListen
- UINT
Port
- BYTE
ReadSSIDFromScan
- BYTE
Index
| SSID Index
- STRING
CreateAccessPoint
- STRING
SSID
- STRING
Password
- BYTE
- BYTE
Encryption
- BYTE
ReadIP
- BYTE
Index
- BYTE
SocketWrite
- STRING
Buffer
- UINT
Size
- UINT
Disconnect
- BYTE
- BYTE
Index
| SSID Index
- INT
- BYTE
Index
| SSID Index
- BYTE
ConnectToSSID
- STRING
SSID
- STRING
Key
- BYTE
Timeout
- BYTE
SocketOpen
- BYTE
SocketClose
Uninitialise
- BYTE
AcceptOpen
- BYTE
ScanForSSID
- BYTE
SocketRead
- STRING
Buffer
- UINT
Size
- UINT
AcceptClose
- BYTE
Verbose Debug
Network Interface
