| Author
| Version
1.0
| Category
Comms: Networking
Hydro Encryption component
A cipher suite to enable encryption and decryption of data messages, based on libhydrogen.
Please click here to download the component source project: FC_Comp_Source_libhydrogen.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_libhydrogen.fcfx
sign_create
| Computes a signature for a message using the secret key. Returns 0 if successful.
- BYTE
signature
| Buffer to receive the signature. Must be 64 bytes.
- BYTE
message
| Buffer containing the data to sign
- UINT
message_size
| Byte count of the message
- BYTE
secret_key
| Secret/Private key to be used.Size is 64 bytes.
- INT
secretbox_keygen
| Creates a secret key suitable for use with the secretbox functions. You must provide a 32 byte array for the key.
- BYTE
key
hash_with_key
| Creates a hash fingerprint of the data, using the given key. Returns 0 if successful.
- BYTE
hash
| Buffer for the hash. Size >=32 makes it practically impossible for two messages to produce the same fingerprint.
- BYTE
data
| The data buffer to be processed
- UINT
size
| Byte count of the data to be processed
- BYTE
key
| Key to be used
- INT
sign_verify
| Verify the signature of a mesasge using the public key. Returns 0 if successful.
- BYTE
signature
- BYTE
message
- UINT
message_size
- BYTE
public_key
| Public key to be used.Size is 32 bytes.
- INT
init
| Initialisation function. To be called at the very start of your program.
- INT
sign_keygen
| Creates Private and Public key pair to sign and verify messages. Returns 0 if successful.
- BYTE
Secret
| Buffer to receive the Private/Secret Key. Buffer size must be 64 bytes
- BYTE
Public
| Buffer to receive the Public key. Buffer size must be 32 bytes
- INT
secretbox_encrypt
| Encrypts a message with a secret key. A single key is used both to encrypt/sign and verify/decrypt messages. For this reason, it is critical to keep the key confidential. Returns 0 on success.
- BYTE
message
| Buffer containing the message to be encrypted.
- UINT
length
| The length (byte count) of the message
- UINT
ID
| Message ID. Can be 0
- BYTE
key
| The secret key
- BYTE
ciphertext
| Buffer for ciphertext output. Buffer size must be at least length + 36
- INT
hash_keygen
| Creates a secret key suitable for use with the hash_hash function. You must provide a 32 byte array for the key.
- BYTE
key
secretbox_decrypt
| Decrypts a message with a secret key. A single key is used both to encrypt/sign and verify/decrypt messages. For this reason, it is critical to keep the key confidential. Returns 0 on success.
- BYTE
message
| Buffer for the decrypted message. Size must be at least length - 36
- UINT
length
| The length (byte count) of the ciphertext
- UINT
ID
| Message ID. Must match with the original message ID. Can be 0
- BYTE
key
| The secret key
- BYTE
ciphertext
| Buffer containing the ciphertext to be decrypted.
- INT
hash_without_key
| Creates a hash fingerprint of the data, which will always have the same fingerprint, similar to the MD5 or SHA-1 Returns 0 if successful.
- BYTE
hash
- BYTE
data
| Data buffer to be processed
- UINT
size
| Byte count of data to be processed
- INT
sign_create
- BYTE
signature
- BYTE
message
- UINT
message_size
- BYTE
secret_key
- INT
secretbox_keygen
- BYTE
key
hash_with_key
- BYTE
hash
- BYTE
data
- UINT
size
- BYTE
key
| Key to be used
- INT
sign_verify
- BYTE
signature
- BYTE
message
- UINT
message_size
- BYTE
public_key
- INT
init
- INT
sign_keygen
- BYTE
Secret
- BYTE
Public
- INT
secretbox_encrypt
- BYTE
message
- UINT
length
- UINT
ID
- BYTE
key
| The secret key
- BYTE
ciphertext
- INT
hash_keygen
- BYTE
key
secretbox_decrypt
- BYTE
message
- UINT
length
- UINT
ID
- BYTE
key
| The secret key
- BYTE
ciphertext
- INT
hash_without_key
- BYTE
hash
- BYTE
data
- UINT
size
- INT
sign_create
- BYTE
signature
- BYTE
message
- UINT
message_size
- BYTE
secret_key
- INT
secretbox_keygen
- BYTE
key
hash_with_key
- BYTE
hash
- BYTE
data
- UINT
size
- BYTE
key
| Key to be used
- INT
sign_verify
- BYTE
signature
- BYTE
message
- UINT
message_size
- BYTE
public_key
- INT
init
- INT
sign_keygen
- BYTE
Secret
- BYTE
Public
- INT
secretbox_encrypt
- BYTE
message
- UINT
length
- UINT
ID
- BYTE
key
| The secret key
- BYTE
ciphertext
- INT
hash_keygen
- BYTE
key
secretbox_decrypt
- BYTE
message
- UINT
length
- UINT
ID
- BYTE
key
| The secret key
- BYTE
ciphertext
- INT
hash_without_key
- BYTE
hash
- BYTE
data
- UINT
size
- INT
sign_create
- BYTE
signature
- BYTE
message
- UINT
message_size
- BYTE
secret_key
- INT
secretbox_keygen
- BYTE
key
hash_with_key
- BYTE
hash
- BYTE
data
- UINT
size
- BYTE
key
| Key to be used
- INT
sign_verify
- BYTE
signature
- BYTE
message
- UINT
message_size
- BYTE
public_key
- INT
init
- INT
sign_keygen
- BYTE
Secret
- BYTE
Public
- INT
secretbox_encrypt
- BYTE
message
- UINT
length
- UINT
ID
- BYTE
key
| The secret key
- BYTE
ciphertext
- INT
hash_keygen
- BYTE
key
secretbox_decrypt
- BYTE
message
- UINT
length
- UINT
ID
- BYTE
key
| The secret key
- BYTE
ciphertext
- INT
hash_without_key
- BYTE
hash
- BYTE
data
- UINT
size
- INT
