Component: Potentiometer (Black) ()
Revision as of 10:01, 27 January 2023 by Wiki bot (talk | contribs)
Version 1.4
Category
Potentiometer (Black) component
Potentiometer with black plastic knob. Pointer colour can be changed in component properties.
Please click here to download the component source project: FC_Comp_Source_pot_Black.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_pot_Black.fcfx
FC6 Icon.png Potentiometer Example
Fc9-conn-icon.png Simulation
Fc9-type-15-icon.png Start Angle
Fc9-type-15-icon.png Sweep Angle
Fc9-type-1-icon.png Color
Colour of the pointer.
Fc9-type-7-icon.png Retain Value
If yes is slected After saving your project, the ADC value will be retained when your project is reloaded.
Fc9-type-6-icon.png Channel
Fc9-conn-icon.png Settings
