Component: DAC (Internal) (Analog Output)
Version | 2.0 |
Category | Analog Output |
DAC (Internal) component
Provides access to the onboard digital to analog converter (DAC) peripheral allowing for simple analogue output. Often the DAC output will be very low current and will need amplification using external circuitry to drive anything useful.
Please click here to download the component source project: FC_Comp_Source_DAC.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DAC.fcfx
SetOutput |
Sets the output voltage of the DAC | |
DAC_Value |
The value to output to the DAC | |
Return |
GetValue |
Gets the Name property value | |
Name |
The name of the property | |
Return |
Disable |
Disables the DAC output. | |
Return |
Enable |
Enables the DAC Output. | |
Return |
SetValue |
Sets the Value for the named property | |
Name |
Name of property to update | |
Value |
The new value for the property | |
Return |
GetList |
Name |
Return |
SetOutput |
DAC_Value |
Return |
GetValue |
Name |
Return |
Disable |
Return |
Enable |
Return |
SetValue |
Name |
Value |
Return |
GetList |
Name |
Return |
SetOutput |
DAC_Value |
Return |
GetValue |
Name |
Return |
Disable |
Return |
Enable |
Return |
SetValue |
Name |
Value |
Return |
GetList |
Name |
Return |
SetOutput |
DAC_Value |
Return |
GetValue |
Name |
Return |
Disable |
Return |
Enable |
Return |
SetValue |
Name |
Value |
Return |
GetList |
Name |
Return |
SetOutput |
DAC_Value |
Return |
GetValue |
Name |
Return |
Disable |
Return |
Enable |
Return |
SetValue |
Name |
Value |
Return |
GetList |
Name |
Return |
