| Author
Matrix Ltd
| Version
2.1
| Category
Wireless
Bluetooth (HC05 / HC06) component
Low level routines for controlling or interacting with a HC05 or HC06 Bluetooth module. Contains functions to allow the baud rate, bluetooth name and bluetooth key to be defined.
Please click here to download the component source project: FC_Comp_Source_BTHC05.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_BTHC05.fcfx
Example Program that configures a HC05 / HC06 Bluetooth module and then allows a data connection to be established and utilised.
Incoming data will be displayed on an LCD.
Outgoing data is assigned and sent using a keypad component.
HC05 Example
SetPairKey
| Sets the Bluetooth pair key stored in the Bluetooth module's ROM. Commands must be sent before Bluetooth communications are estabished e.g. right after power on and initialisation.
- STRING
Key
| Four digit pair key e.g. "0000" or "1234"
SendString
| Sends out a string of bytes from the UART interface.
- STRING
Data
SendCommand
| Sends a command string to the HC05/HC06 module.
- STRING
Command
SetBaud
| Sets the Bluetooth baud rate stored in the Bluetooth module's ROM. Commands must be sent before Bluetooth communications are estabished e.g. right after power on and initialisation.
- BYTE
Baud
| 1=1200, 2=2400, 3=4800, 4=9600, 5=19200, 6=NA, 7=38400, 8=57600, 9=115200
SendNumber
| Sends out a number as an ASCII String from the UART interface.
| [[File:]] -
Number
SendChar
| Sends out a single packet from the UART interface.
- INT
Char
SetName
| Sets the Bluetooth Friendly name stored in the Bluetooth module's ROM. Commands must be sent before Bluetooth communications are estabished e.g. right after power on and initialisation.
- STRING
Name
| Name you wish to provide to the module
ReceiveString
| Attempts to receive a string of bytes from the UART interface.
- BYTE
Timeout
- BYTE
NumBytes
- STRING
| Sets up the RS232 peripheral, must be called at the start of your program or at least before you start calling any other RS232 macros.
ReceiveChar
| Attempts to receive a single packet from the UART interface.
- INT
Timeout
| Time to wait for valid data before returning, 0=Dont wait, 255=Wait forever.
- INT
Comms Settings
Data Bits
| Number of data bits
| Return data width from Receive macro. 8-bit data mode always returns a byte ranging from 0-255, 255 could mean a timeout or could be a valid data. 16-bit data mode rereturns 0-255 for valid data, 256 for a timeout, return data must be stored into an INT or UINT variable.
Echo
| Echo selection
Baud Options
| Baud rate option selector
| UART Channel selector Software channels are bit banged using generic I/O pins but are not as reliable as hardware channels. Hardware channels use the selected peripheral on-board the target microcontroller.
Use TX
| Selects if the Transmit pin is used by the component. Yes: The TX pin is active and used to transmit data for the UART. No: The TX pin is disabled and free to be used as general I/O.
TX
| Pin to be used for Transmit data
Use RX
| Selects if the Receive pin is used by the component. Yes: The RX pin is active and used to receive data for the UART. No: The RX pin is disabled and free to be used as general I/O.
RX
| Pin to be used for Receive data
Use Flow Control
| Flow Control (Handshake) enable or disable. On: Two I/O pins are used to control the flow of data in and out of the device. Off: Flow control is disabled.
| Textual label shown on the component I/O flasher
| Selects if the scope traces are automatically added to the data recorder window or not. Simulation - draws an approximation of the UART data onto the scope trace. ICT - sets up the scope trace for incoming data and adds UART packet decoding at the correct BAUD.
Console Columns
| Number of characters that can be displayed on a single line of the console.
Data Source
| Simulation data source used to allow the component to connect to various remote devices Nothing - Simulation data is ignored COM port - Routes the communication data to and from a physical or virtual COM port API - Routes the communication data via a data injector component on the Panel.
