Component: Beam Breaker (Light)
Revision as of 16:46, 30 January 2023 by Wiki bot (talk | contribs)
Version 1.1
Category Light
Beam Breaker component
Automatically sets and resets a pin depending on whether a panel object breaks the 'light beam'. Can also send simulation notification events.
Please click here to download the component source project: FC_Comp_Source_Beam_breaker.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Beam_breaker.fcfx
ReadState
Get the current collision state. The 'Polarity' property will affect whether a collision is represented by a high or low state.
SetTarget
Set the object that you want to test for collision with. If this is not called, or is called with handle = 0, collisions will be tested against every panel object that has 'Solid' status. NB) Specifying an object will save CPU power!!
- HANDLE Target
The object to test for collision with.
WaitUntilHigh
Pause the program until the detector goes high. 'Polarity' will affect whether high value represents a collision or separation. NB) In simulation, only use this macro if testing for collision with animated or timer driven objects!!
WaitUntilLow
Pause the program until the detector goes low. 'Polarity' will affect whether low value represents a collision or separation. NB) In simulation, only use this macro if testing for collision with animated or timer driven objects!!
Pin
Chip pin that the beam breaker is connected to,.
Polarity
Active High = Pin is on when beam is broken, off when beam is intact. Active Low = Pin is off when beam is broken, on when beam is intact.
Target
Choose a specific object to test for breaking the beam. If none is chosen, will check against any other object with 'Solid' status - note, checking all objects increases the CPU load!!
Range
Set the distance between the transmitter and receiver
Show Beam
Shows the 'light beam' on screen - arrow points from transmitter to receiver.
Timer Interval (ms)
Time in milliseconds between collision scans. Small time = Greater CPU load Large time = More like to miss brief collisions.
Notification
Notify
Whether or not to notify the component parent of any changes. Data will be zero or one (the current pin value).
