| Author
Matrix Ltd
| Version
1.6
| Category
Graphical Monochrome
GLCD (ST7036) I2C component
Graphical display component based on the I2C version of the ST7036 monochrome graphical controller IC. Functions without the use of a read pin by hosting the 1K of graphical memory using the  microcontroller's RAM memory.
Please click here to download the component source project: FC_Comp_Source_GLCD_ST7036_I2C.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_ST7036_I2C.fcfx
ReadFontWidth
  - BYTE
Font
  - BYTE
Character
  - BYTE
SetFontScaler
  - BYTE
ScaleX
  - BYTE
ScaleY
SendCommand
  - BYTE
Command
  - INT
Number
  - UINT
X
  - UINT
Y
  - BYTE
Font
  - BYTE
Transparent
DrawLine
  - UINT
X1
  - UINT
Y1
  - UINT
X2
  - UINT
Y2
DrawEllipse
  - UINT
X
  - UINT
Y
  - UINT
XRadius
  - UINT
YRadius
  - BYTE
Transparent
  - BYTE
Solid
Plot
  - UINT
X1
  - UINT
Y1
ControlDisplay
| Allows the display to be switched on and off
  - BYTE
Control
| 0=Off, 1=On
SetDisplayOrientation
  - BYTE
Orientation
BPlot
  - UINT
X1
  - UINT
Y1
ReadFontStat
  - BYTE
Font
  - BYTE
Index
| 0=SpaceWidth, 1=PixelHeight
  - BYTE
Print
  - STRING
Str
  - UINT
X1
  - UINT
Y1
  - BYTE
Font
  - BYTE
Transparent
ControlContrast
| Sets the display contrast from 0 to 255.
  - BYTE
Contrast
| Range 0 - 255, Default 207
ClearDisplay
SetBackgroundColour
  - BYTE
PixelColour
| 0=White, 1=Black
DrawCircle
  - UINT
X
  - UINT
Y
  - UINT
Radius
  - BYTE
Transparent
  - BYTE
Solid
SetForegroundColour
  - BYTE
PixelColour
| 0=White, 1=Black
DrawRectangle
  - UINT
X1
  - UINT
Y1
  - UINT
X2
  - UINT
Y2
  - BYTE
Transparent
  - BYTE
Solid
InvertDisplay
Dimensions
Pixel Width
Pixel Height
Interlaced
| Determines if the display is interlaced in the Y axis or not
Colour
Monochrome
Foreground Color
Background Color
Bit Depth
Colour Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
| Channel selection
Baud Select
| Baud rate option selector
| Baud rate to be used
Stop Delay
| On older microcontroller devices there is a potential for the I2C hardware channel to lock up if there is not  a 10ms delay between an I2C stop event and the next I2C start event.  Most modern microcontrollers will not have a problem so this property can be disabled to speed up the  I2C communications.
SDA
SCL
Reset Pin
Fonts
Font Count
Font 0
Font
Character Spacing
Space Width
Simulation Mode
Physical Orientation
Simulate Comms
| Allows the communications to be simulated to either see the waveforms on the data recorder or to drive an injector component.
