Component: Colour Sensor (Grove 101020341) (101020341) (Light)
| Category | Light |
Colour Sensor (Grove 101020341) component
Based on the color sensor TCS34725FN with digital output I2C. Based on the 8*2 array of filtered photodiodes and 16-bits analog-to-digital converters, you can gain the color chromaticity of ambient light or the color of objects. Of the 16 photodiodes, 4 have red filters, 4 have green filters, 4 have blue filters and 4 have no filter(clear). With the synchronization input pin, external pulsed light source can provides precise synchronous conversion control.
Please click here to download the component source project: FC_Comp_Source_I2C_Colour_Sensor.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_I2C_Colour_Sensor.fcfx
| SetGain | |
| Controls the gain. 0x00 = 1X 0x01 = 4X 0x02 = 16X 0x03 = 60X | |
| Setting | |
| Range: 0 to 3 | |
| ClearInterrupt | |
| Clears the interrupt flag allowing the device to interrupt again. | |
| CalculateTemp | |
| Uses the RGB values stored in RAM from the last Sample to calculate the colour temperature in degrees Kelvin. | |
| EnableSensor | |
| Powers up the device ready for taking colour readings. | |
| CalculateLux | |
| Uses the RGB values stored in RAM from the last Sample to calculate the luminance in lux. | |
| SampleSensor | |
| Reads the raw colour channels from the sensor and stores the readings into RAM to be collected by the ReadDataChannel macro. | |
| DisableSensor | |
| Powers down the device to save power. | |
| SetIntegrationTime | |
| Controls the integration time. 0 = 700mS / 1 = 154mS / 2 = 101mS / 3 = 50mS / 4 = 24mS / 5 = 2.4mS | |
| Setting | |
| Range: 0 to 5 | |
| Initialise the sensor configuration as set by the component properties. Sets the default intigration time and gain as well as enable the sensor. | |
