Component: IO Expander (PCF8575) (PCF8575) (General Input)
Revision as of 16:48, 30 January 2023 by Wiki bot (talk | contribs)
Category General Input
IO Expander (PCF8575) component
Provides 16 digital input/output pins arranged into 8-bit ports using a I2C bus connection. Up to eight expanders can be connected to the same I2C peripheral by means of three address pins. Supports the PCF8575 device allowing up to 8 expanders to be connected to the same I2C bus.
Please click here to download the component source project: FC_Comp_Source_IOEXP_PCF8575.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_IOEXP_PCF8575.fcfx
ReadPort
Reads the current input value of the I/O pins.
WritePort
Writes an output value to the IO pins
- UINT Value
Value to write. Range 0-65535
I²C Communications
Device Type
External Address
Selects the value of the three address pins for the MCP23S17.
Channel selection
Stop Delay
Baud Select
Baud rate to be used
SDA
SCL
API
