Component: Injector (DS1307 RTC) ()
| Author | Matrix Ltd |
| Version | 1.1 |
| Category |
Injector (DS1307 RTC) component
Comms data injector to allow simulation of a DS1307 Real Time Clock and RAM.
Please click here to download the component source project: FC_Comp_Source_InjectorDS1307.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_InjectorDS1307.fcfx
I2C DS1307 Example
| InitialiseInjector | |
| Sets up the injector ready to receive commands or send data | |
| InjectorName | |
| Name of the console that will be created | |
| RxByteCount | |
| Returns the number of bytes currently sat in the receive buffer. | |
| TxByte | |
| Puts a byte onto the comms channel. | |
| DataByte | |
| RxByte | |
| Attempt to receive a byte back from the injector 0 - 255 = Valid data 256 = RX timeout no data available | |
| GetConsoleHandle | |
| Gets the handle to the console allowing data displaying on the panel etc. | |
| ChangeState | |
| Changes the state for I2C or SPI type comms where the data bytes along are not enough to go on. | |
| NewState | |
| Properties | |
| DS1307 Injector Settings | |
| Circular Buffer Size | |
| Termination Character | |
| Device Address | |
| Day Setting | |
| Configures how the day of the week is calculated. | |
