Component: MIAC NXT AllCode API (AllCode)
| Version | 1.1 |
| Category | AllCode |
MIAC NXT AllCode API component
Controls the MIAC NXT hardware loaded with the MIAC NXT AllCode firmware. Usefull for SCADA, Control or Test applications. Compatible with USB / Bluetooth / Wifi / Ethernet
Please click here to download the component source project: FC_Comp_Source_MIAC_NXT_AllCode_Component_Source.fcsx
Please click here to view the component source code (Beta): FC_Comp_Source_MIAC_NXT_AllCode_Component_Source.fcsx
| WriteTrans | |
| Allows all transistor outputs to be switched on or off in a single command. | |
| Value | |
| Range: 0-63 or 0b000000 to 0b111111 | |
| DisplayPrint | |
| Prints a string to the MIAC display starting from the current cursor position. | |
| data | |
| Range: 0-21 | |
| GetAPIVersion | |
| Gets the API version of the MIAC NXT AllCode Firmware. Useful to see if the MIAC NXT is responding to commands. | |
| DisplayNumber | |
| Prints a number to the MIAC display starting from the current cursor position. | |
| Value | |
| Range: Signed Long | |
| WriteTranPWMDuty | |
| Sets the PWM duty on the selected channel. | |
| Channel | |
| Range: 1-4 Where 1=A / 2=B / 3=C / 4=D | |
| EnableOrState | |
| 1 = Enable / 0 = State | |
| Duty | |
| DisplayClear | |
| Clears the MIAC display | |
| ReadKey | |
| Reads a keypress from the keypad. Returns 0 for no keypress or 1-9 for a valid keypress. 1 = TopLeft, 2=TopMiddle, 3=TopRight, 4=CenterLeft etc | |
| DisplayPixel | |
| Controls a single pixel on the MIAC display | |
| X | |
| Range: 0-119 | |
| Y | |
| Range: 0-31 | |
| State | |
| Range: 0-1 | |
| WriteRelay | |
| Allows a single relay to be switched on or off. | |
| Channel | |
| Range 1-2 | |
| Value | |
| 0 = Off, 1 = On | |
| WriteRelays | |
| Allows all relays to be switched on or off in a single command. | |
| Value | |
| Range: 0-3 or 0b00 to 0b11 | |
| ReadAnalogInput | |
| Reads a single analog input with range 0 to 4095 corresponding to input voltage 0V to +V. | |
| Channel | |
| Range: 1 - 8 | |
| DisplayCursor | |
| Sets the cursor position for the MIAC display | |
| X | |
| Range: 0-21 | |
| Y | |
| Range: 0-3 | |
| ReadDigitalInput | |
| Reads a single digital input. | |
| Channel | |
| Range: 1 - 8 | |
| ReadDigitalInputs | |
| Reads all digital inputs at once and returns as a binary value. Input 1 = Bit 0 Input 8 = Bit 7 | |
| WriteTran | |
| Allows a single transistor output to be switched on or off. | |
| Channel | |
| Range 1-6 where 1=A / 2=B / 3=C / 4=D / 5=E / 6=F | |
| Value | |
| 0 = Off, 1 = On | |
| DisplayFloat | |
| Prints a floating point number to the MIAC display starting from the current cursor position. | |
| Value | |
| Range: Float | |
| NumDP | |
| Number of decimal places to display | |
