Component: SPI (CAL) (Misc)
| Version | 2.1 |
| Category | Misc |
SPI component
CAL = Code Abstraction Layer - Allows one code base to run on a wide range of chips. A low level implementation giving direct access to the Serial Peripheral Interface peripheral.
Please click here to download the component source project: FC_Comp_Source_SPI.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_SPI.fcfx
| Master_Enable_CS | |
| Outputs a low signal to the chip select pin to select the remote slave device. | |
| Slave_Uninit | |
| Uninitialise the Slave | |
| GetValue | |
| Reads Named property Value. | |
| Name | |
| Slave_Init | |
| Initialise the Slave | |
| Master_Disable_CS | |
| Outputs a high signal to the chip select pin to deselect the remote slave device. | |
| Master_Uninit | |
| Uninitialise the Master | |
| Master_Byte | |
| Sends and receives a data byte | |
| DataOut | |
| GetConsoleHandle | |
| Returns a handle to the console used by this component | |
| Slave_TxByte | |
| Sets the data to be transmitted to the SPI master. | |
| Data | |
| Slave_RxByte | |
| Returns the data received from the SPI Master | |
| SetValue | |
| Change Named property to new Value. | |
| Name | |
| Value | |
| SetPrescaler | |
| Sets the prescaler value for the clock divider chain | |
| Prescaler | |
| Master_Init | |
| Initialise the Master | |
| GetList | |
| returns Named property list | |
| Name | |
