Component: TCP/IP (EB023 v2) (E-blocks 1)
| Version | 2.0 |
| Category | E-blocks 1 |
TCP/IP component
TCP/IP component designed to work with the WIZ810MJ module from Wiznet, as used on version 2 EB023 E-block and the MIAC Industrial Addon module.
Please click here to download the component source project: FC_Comp_Source_TCPIP_EB023-00-2_EB.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_TCPIP_EB023-00-2_EB.fcfx
Error creating thumbnail: Unable to save thumbnail to destination
TxSendMyIP |
| This macro fills the specified channel's transmit buffer with 4 bytes of data representing this Internet E-Block's IP address as specified in the component's property page. | |
Error creating thumbnail: Unable to save thumbnail to destination - BYTE
Channel |
| Specifies the communications channel 0-3 | |
Error creating thumbnail: Unable to save thumbnail to destination - VOID
Return |
RxMatchMyIP |
| This macro returns a non-zero value when the next 4 bytes of data in the specified channel's reception buffer are the same as the Internet E-block's IP address. | |
Channel |
Return |
RxMatch_4_Bytes |
| This macro returns a non-zero value when the next 4 bytes of data in the specified channel's reception buffer are the same as those passed as parameters. There are similar functions that check for 2 bytes and 6 bytes. | |
Channel |
Byte1 |
| Specifies the value of the first byte | |
Byte2 |
| Specifies the value of the second byte | |
Byte3 |
| Specifies the value of the third byte | |
Byte4 |
| Specifies the value of the fourth byte | |
Return |
SetMyIP |
| This macro sets up the Internet E-Block's own IP address. In most circumstances, this macro will not be required as the IP address setting in the component property page will remain constant throughout your application. | |
IP0 |
| First Byte of IP address | |
IP1 |
| Second Byte of IP address | |
IP2 |
| Third Byte of IP address | |
IP3 |
| Fourth Byte of IP address | |
Return |
TxSendString |
| This macro fills the specified channel's transmit buffer with data. It can fill the buffer with a string of information. | |
Channel |
Error creating thumbnail: Unable to save thumbnail to destination - STRING
Data |
| Data byte to append to Tx buffer. | |
Length |
Return |
RxReadHeader |
| Once data in a particular channel has been received, the header will be filled with information about the received data. This macro will return the information in the header. The idx parameter specifies which byte of information in the header to read | |
Channel |
Idx |
| Specifies the byte index to return | |
Return |
RxSkipBytes |
| Often when receiving data packets, it may be necessary to ignore large sections of the data. This can be achieved by reading each byte individually (and ignoring the returned data), but a better way is to use this Rx_skipbytes macro. | |
Channel |
Count |
| Specifies how many bytes to skip | |
Return |
MIAC_Module_SetData |
Count |
D0 |
D1 |
D2 |
D3 |
D4 |
D5 |
Return |
CreateIPSocket |
| Note that sockets on up to 4 channels can be simultaneously opened and these channels are numbered 0 to 3. Note that sockets with different modes can be opened on different channels. | |
Channel |
Protocol |
| Specifies which IP protocol to use | |
Broadcast |
| Allows broadcast type packets to be sent and received | |
Return |
SetDestination |
| This is used in IP and UDP modes to set the destination of the intended data transfer. The destination IP address needs to be set for both IP and UDP modes. | |
Channel |
Dst_IP0 |
| Specifies the first byte of an IP address | |
Dst_IP1 |
| Specifies the second byte of an IP address | |
Dst_IP2 |
| Specifies the third byte of an IP address | |
Dst_IP3 |
| Specifies the fourth byte of an IP address | |
Error creating thumbnail: Unable to save thumbnail to destination - UINT
Dst_Port |
| Destination Port | |
Return |
MIAC_Module_GetData |
Index |
Return |
TxStart |
| This macro indicates the start of data transmission for the specified buffer. In TCP mode, data transmission can only begin once the socket has become established. In other modes, data transmission can occur as soon as the socket has been opened. | |
Channel |
Return |
MIAC_Module_Message |
CAN_ID |
CMD_ID |
Return |
RxReadByte |
| A call to this macro will return a byte of data in the reception buffer of the specified channel. It will also internally increment a pointer to that data so that the next call to 'Rx_readbyte' (or any other read function) will read the next byte | |
Channel |
Return |
CreateUDPSocket |
| This macro creates a socket for sending and receiving UDP data. | |
Channel |
Src_Port |
| Port Number | |
Return |
RxMatch_6_Bytes |
| This macro returns a non-zero value when the next 6 bytes of data in the specified channel's reception buffer are the same as those passed as parameters. There are similar functions that check for 2 bytes and 4 bytes. | |
Channel |
Byte1 |
Byte2 |
Byte3 |
Byte4 |
Byte5 |
| Specifies the value of the fifth byte | |
Byte6 |
| Specifies the value of the sixth byte | |
Return |
RxMatch_2_Bytes |
| This macro returns a non-zero value when the next 2 bytes of data in the specified channel's reception buffer are the same as those passed as parameters. There are similar functions that check for 4 bytes and 6 bytes. | |
Channel |
Byte1 |
Byte2 |
Return |
TxEnd |
| Once the transmit buffer has been filled with data, call this macro to actually send the data. | |
Channel |
Return |
RxReadString |
| A call to this macro will return a string of data in the reception buffer of the specified channel. It will also internally increment a pointer to that data so that the next call to 'Rx_readbyte' (or any other read function) will read the next byte | |
Channel |
Length |
Return |
CreateTCPSocket |
| This macro creates a socket for sending and receiving TCP data. | |
Channel |
Src_Port |
| Port Number | |
Return |
RxDataAvailable |
| This macro is used to check whether or not data has been received by the Internet E-Block. A return value of zero indicated that no data has been received. A positive return value indicates that data is available. | |
Channel |
Return |
MIAC_Module_PushData |
Data |
Return |
TxSendByte |
| This macro fills the specified channel's transmit buffer with data. It can fill the buffer with a single byte of data, or with a string of information. | |
Channel |
Data |
Return |
TCPListen |
| This macro puts a previously opened TCP channel in "passive open" mode. This is the required mode when writing a TCP server application (e.g. a web server to display HTML web pages). | |
Channel |
Return |
TxSendByte_Sim |
Channel |
Data |
Return |
RxFlushData |
| Once data reception has been completed, this macro should be called to discard the data packet and allow other data packets to be read. | |
Channel |
Return |
TCPConnect |
| This macro puts a previously opened TCP channel in "active open" mode. This is the required mode when writing a TCP client application (e.g. using SMTP to send an email). | |
Channel |
Dst_IP0 |
Dst_IP1 |
Dst_IP2 |
Dst_IP3 |
Dst_Port |
Return |
RxReadByte_Sim |
Channel |
Return |
RxMatchMyMAC |
| This macro returns a non-zero value when the next 6 bytes of data in the specified channel's reception buffer are the same as the Internet E-block's MAC address entered in the component's property page. | |
Channel |
Return |
RxFlushData_Sim |
Channel |
Return |
RxDataSize |
| This macro is used to detect the size of data collected by the Rx_data_available macro. | |
Channel |
Return |
CreateMACSocket |
| This macro creates a socket for sending and receiving Ethernet data using raw data. | |
Promiscuous |
| Receive everything (1) or just data bound for your MAC (0) | |
Broadcast |
| Allows broadcast messages to be accepted (1) or rejected (0) | |
Error |
| Allowsmessages with errors to be accepted (1) or rejected (0) | |
Return |
CreateUDPSocket_Sim |
Channel |
Src_Port |
| Port Number | |
Return |
TxSendMyMAC |
| This macro fills the specified channel's transmit buffer with 6 bytes of data representing this Internet E-Block's MAC address as specified in the component's property page. | |
Channel |
Return |
SetMACAddress |
| This macro sets up the Internet E-Block's MAC address. In most circumstances, this macro will not be required as the MAC address setting in the component property page will remain constant throughout your application. | |
MAC0 |
| First Byte of address | |
MAC1 |
| Second Byte of address | |
MAC2 |
| Third Byte of address | |
MAC3 |
| Fourth Byte of address | |
MAC4 |
MAC5 |
| Fifth Byte of address | |
Return |
RxMatch_4_Bytes_Sim |
Channel |
Byte1 |
Byte2 |
Byte3 |
Byte4 |
Return |
RxDataSize_Sim |
Channel |
Return |
SetSubnetMask |
| This macro sets up the Internet E-Block's Subnet Mask. In most circumstances, this macro will not be required as the subnet mask setting in the component property page will remain constant throughout your application. | |
IP0 |
IP1 |
IP2 |
IP3 |
Return |
RxMatch_2_Bytes_Sim |
Channel |
Byte1 |
Byte2 |
Return |
RxMatchMyMAC_Sim |
Channel |
Return |
TCPClose |
| When an established TCP connection has finished transmission of data, either the local application (i.e. your code) or the remote application (i.e. the application at the other end of the connection) can initiate closure of the socket. | |
Channel |
Return |
GetSocketStatus |
| This returns the state of the requested channel's socket. | |
Channel |
Return |
Initialise |
| Resets and initialises the Internet E-Block. It sets up the gateway address, subnet mask, device IP address and device MAC address as defined in the properties of the Flowcode component. This macro must be called before any other TCP_IP component macros | |
Return |
SetGateway |
| This macro sets up the Internet E-Block's Gateway address. In most circumstances, this macro will not be required as the gateway address setting in the component property page will remain constant throughout your application. | |
IP0 |
IP1 |
IP2 |
IP3 |
Return |
Properties |
Connections |
Channel |
| SPI Channel selector | |
Prescale |
| Prescale option selector | |
MOSI |
| SPI Data Out Pin SDO - Also Known as Master Out Slave In (MOSI) when used in Master mode. | |
MISO |
| SPI Data In Pin SDI - Also Known as Master In Slave Out (MISO) when used in Master mode. | |
CLK |
| SPI Clock Pin CLK - The Clock signal is driven by the SPI master. | |
CS / SS |
| Chip Select / Slave Select Pin Master Mode: General purpose output pin used to select the remote SPI device. Slave Mode: Hardware chip select pin input used to select the SPI device. | |
Gateway IP |
Gateway0 |
Gateway1 |
Gateway2 |
Gateway3 |
Subnet Mask |
Subnet0 |
Subnet1 |
Subnet2 |
Subnet3 |
IP Address |
IP0 |
IP1 |
IP2 |
IP3 |
MAC Address |
MAC0 |
MAC1 |
MAC2 |
MAC3 |
MAC4 |
MAC5 |
Simulation |
Label |
Sim Type |
| Decides how to perform the simulation of the component. TCP IP - Communicates using the Windows TCP IP communications DLL SPI / API - Communicates using the CAL SPI to allow the communications to be analysed and debugged. | |
SPI Simulation |
Scope Traces |
| Selects if the scope traces are automatically generated or not | |
Console Data |
| Selects if the console data is automatically generated or not | |
API |
