| Author
Matrix Ltd.
| Version
2.1
| Category
Comms: Networking
WLAN (ESP-12S) component
Wireless LAN component designed to work with the ESP-12S module. Provides a very simple interface to allow webpages to be hosted from hardware or simulation. Also available in the form of the BL0136 WIFI E-block.
Please click here to download the component source project: FC_Comp_Source_WLAN_ESP12S.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_WLAN_ESP12S.fcfx
SendString
| Sends the given Text with no preappendment. Useful for sending preformatted command strings. Appends a CR to the end of the string if SendCR is greater than 0.
  - STRING
Text
  - BYTE
SendCR
DisconnectFromSSID
| Disconnects from the current SSID.  Returns 1 if the command was accepted and returned an "OK"
  - BYTE
ClientConnect
| Creates a TCP or UDP connection to a remote server. Returns the state of the connection. 0=Connection failed 1=Connection active
  - BYTE
Type
| 0 = TCP, 1 = UDP
  - STRING
IPAddress
| e.g. "192.168.1.20"
  - UINT
Port
| Remote port number to connect to, HTTP comms = Port 80
  - BYTE
ControlTCPServer
| Allows a TCP web page server to be switched on and off on the selected port. Returns 1 if the command was completed correctly.
  - BYTE
Enable
| 0 = Stop Server, 1 = Start Server
  - UINT
Port
| Server port to listen for incoming TCP/IP data requests
  - BYTE
GetFirmwareVersion
| Collects the firmware version from the ESP8266 module and returns it as a string.
  - STRING
CheckForPageRequests
| To be called periodically. Returns non-zero if a request has been processed
  - BYTE
ClientSendRequest
| Sends out a string with the required AT+CIPSEND=Length$(Request) initialiser.
  - STRING
Request
| e.g. "GET / HTTP/1.0\r\n\r\n"
ReadSSIDFromScan
| Collects one of the SSID name strings from the last SSID Scan. The ScanForSSID macro must be called first.
  - BYTE
Index
| SSID Index
  - STRING
CreateAccessPoint
| Sets up the wireless LAN module into AP mode to host a wireless network. Other WIFI enabled devices can then connect to the module. Returns 1 for success.
  - STRING
SSID
| Name of the wireless network to create
  - STRING
Password
| Password used to gain access to the network
  - BYTE
| 802.11 Channel Range 1-14
  - BYTE
Encryption
| 0=Open, 1=WEP, 2=WPA_PSK, 3=WPA2_PSK, 4=WPA_WPA2_PSK
  - BYTE
SetOutValue
| Set the value of an outbound substitution string
  - BYTE
index
| Range 0-4
  - STRING
value
EndServerConnection
| Disconnects from the current active TCP/IP pipe.
  - BYTE
Send_Embedded_HTML_Page4
ReadSignalStrengthFromScan
| Collects the signal strength from the last SSID Scan. The ScanForSSID macro must be called first. Value returned is in negative dB, smaller value = better signal
  - BYTE
Index
| SSID Index
  - INT
Send_Embedded_HTML_Page3
Send_Embedded_HTML_Page2
Send_Embedded_HTML_Page1
ReadEncryptionModeFromScan
| Collects one of the encryption modes from the last SSID Scan. The ScanForSSID macro must be called first. 0=Open, 1=WEP, 2=WPA_PSK, 3=WPA2_PSK, 4=WPA_WPA2_PSK
  - BYTE
Index
| SSID Index
  - BYTE
GetByteWithTimeout
| Attempts to receive a byte from the circular buffer. If nothing is available then waits up to 200 ms for data to become available.
  - BYTE
GetInValue
| Returns the string value of a Request parameter
  - BYTE
index
| Index of the request paramter, starting at zero Range 0-2
  - STRING
ConnectToSSID
| Attempts to connect to the given SSID and Key values.  Returns 1 if the SSID has been connected.
  - STRING
SSID
  - STRING
Key
  - BYTE
Timeout
| Number of seconds to wait for the connection, default 20
  - BYTE
ClientSendArray
| Sends out an array of data bytes with the required AT+CIPSEND=Length$(Request) initialiser.
  - BYTE
Data
  - UINT
NumBytes
GetRxArray
| Attempts to receive a number of bytes from the remote connection If nothing is available then waits up to 200 ms for data to become available. Returns the number of bytes received,.
  - BYTE
Data
| Byte array to store the incoming data
  - UINT
MaxBytes
| Maximum number of bytes to try and receive
  - UINT
ScanForSSID
| Checks for wireless networks in the local area which are broadcasting their SSID. Must not be connected to a network to allow this to function. Returns the number of wireless networks found, max 8.
  - BYTE
| Initialise the device with the property data. Returns 1 if "ready" message successfully received  Returns 0 if no reply from module
  - BYTE
CheckTCPServerIP
| Collects the local IP address of the active TCP server.
  - STRING
WIFI Properties
Receive Buffer Size
| Buffer used to store incoming data ready for processing. Default 128 Bytes.
Scan Buffer Size
| Buffer used to hold SSID names when performing a SSID network scan. Default 100 Bytes.
Reset Mode
| The initialise automatically resets the WIFI module before establishing communications. Software reset uses an AT command to preform the reset Hardware reset uses an extra I/O pin to toggle the signal to the reset pin on the module.
Command Termination
| Older versions of the firmware require \r to terminate a AT command string. Newer versions of the firmware have changed to use \r\n termination.
| UART Channel selector Software channels are bit banged using generic I/O pins but are not as reliable as hardware channels. Hardware channels use the selected peripheral on-board the target microcontroller.
Baud Options
| Baud rate option selector
TX
| Pin to be used for Transmit data
TX Remap Pin
| Allows the hardware transmit pin to be configured from a list of available pins based on your target device,
RX
| Pin to be used for Receive data
RX Remap Pin
| Allows the hardware receive pin to be configured from a list of available pins based on your target device,
Reset
| WLAN module reset pin connection
Use Flow Control
| Flow Control (Handshake) enable or disable.     On: Two I/O pins are used to control the flow of data in and out of the device.     Off: Flow control is disabled.
HTML Source
Max Web Pages
| Maximum number of individual webpages we can serve up with the component.
Web Page Timeout
| Number of cycles to try and send / receive a webpage before timing out.
Line Delay
| Fixed delay in microseconds sent in between sending a HTML line when running as a web page server.
Name Page 1
| HTML name of webpage 1
HTML Page 1
| HTML content for webpage 1
Name Page 2
| HTML name of webpage 2
HTML Page 2
| HTML content for webpage 2
Name Page 3
| HTML name of webpage 3
HTML Page 3
| HTML content for webpage 3
Name Page 4
| HTML name of webpage 4
HTML Page 4
| HTML content for webpage 4
Substitutions
Outgoing
Count
| Maximum number of outbound string substitutions
Length 0
| Number of bytes to reserve for data string.
Incoming
Count
| Maximum number of inbound string substitutions
Length 0
| Text label used to help identify the component on the panel.
Simulation Method
| Decides how to handle the simulation of the component. TCP Base - Allows simulation of the network communications using the TCP Base component and DLL. COM/Injector - Allows the simulation to connect to real hardware or injectors.
| Decides if simulation TCP data is available via a console tab
