Component: ADC Template 2D (Analog Input)
Revision as of 16:50, 30 January 2023 by Wiki bot (talk | contribs)
Version 1.3
Category Analog Input
ADC Template 2D component
Base ADC component with no graphical interface. Contains all of the embedded side component calls to provide an ADC interface suitable for wrapping with a new ADC style component.
Please click here to download the component source project: FC_Comp_Source_adc_Base_2dgdi.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_adc_Base_2dgdi.fcfx
Fc9-comp-macro.png RawSampleInt
Background call to read the ADC at full bit depth Call Enable() first
Fc9-comp-macro.png RawAverageByte
Background call to read the ADC as a byte average sample over time Call Enable() before this
Fc9-u8-icon.png - BYTE NumSamples
Fc9-u8-icon.png - BYTE DelayUs
Number of micro seconds in between taking each sample
Fc9-comp-macro.png GetSampleBits
Gets the number of bits per sample
Fc9-comp-macro.png GetString
Reads the ADC as a direct voltage and returns as a string
Fc9-comp-macro.png GetAverageByte
Function call to read the ADC as a byte average sample over time
Fc9-comp-macro.png RawAverageInt
Background call to read the ADC as a full width average sample over time Call Enable() before this
Fc9-s16-icon.png - INT Return
Fc9-comp-macro.png GetSpeedFilter
Gets the Conversion speed filter string Use in Component.Property.SetFilter()
Fc9-comp-macro.png GetAverageInt
Function call to read the ADC as a full width average sample over time
Fc9-comp-macro.png SetProperties
Set the VRef options and voltage, ConvSpeed and AcqTime for the ADC component.
Fc9-s16-icon.png - INT VRef10Ms
Voltage Reference x10 mV - Default 500 = 5V
Fc9-bool-icon.png - BOOL VRefOpt
External VRef 0=Disabled, 1=Enabled
Fc9-s16-icon.png - INT ConvSpdOpt
Conversion Speed Setting - Refer to numbered list
Fc9-s16-icon.png - INT Aquisitions
Aquisition time in micro seconds to precharge before sampling
Fc9-comp-macro.png GetVoltage
Fc9-comp-macro.png RawEnable
Enables and configures the ADC channel to be an analogue input. Only one ADC channel can be enabled at a time. Any RAW functions will reference the last enabled channel only.
Fc9-comp-macro.png SetChannel
Sets the channel ID for the component
Fc9-s16-icon.png - INT ChannelId
Chaannel starting at 0, -1 is unconnected
Fc9-comp-macro.png RawSampleByte
Background call to read the ADC as a byte Call Enable() before this
Fc9-comp-macro.png GetInt
Blocking call to read the ADC at full bit depth
Fc9-comp-macro.png RawDisable
Disables the previously enabled ADC channel and converts back to digital mode.
Fc9-comp-macro.png GetByte
Blocking call to read the ADC as a byte
Fc9-type-6-icon.png Channel
Fc9-conn-icon.png Settings
Fc9-conn-icon.png Simulation
