Component: Delay (DSP Operators)
Revision as of 11:49, 3 February 2023 by Wiki bot (talk | contribs)
Version 1.2
Category DSP Operators
Delay component
Allows an adjustable delay to be inserted into the DSP system
Please click here to download the component source project: FC_Comp_Source_DSP_Delay.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DSP_Delay.fcfx
Here is a simple example file for the Delay component.
Delay
The DelayADC component is used to set the amount of delay that the component provides 0-2550 samples in steps of 10 samples.
The Input ADC component is used to pass a variable value into the DSP chain to allow the delay to be simulated.
Here is a picture showing the response of the delay component using the data recorder window.
DelayArray
DelayArray
Passes an entire buffer into the delay buffer and spits out a delayed version of the buffer at the other end
Delay
Delay
Passes a single value from a buffer into the delay buffer and spits out a delayed value at the other end
SetDelaySize
SetDelaySize
Specifies the number of values in the delay buffer to allow the length of the delay to be adjustable during runtime.
- UINT Delay_Count
PresetDelay
PresetDelay
Presets the contents of the delay buffer with the specified value.
- UINT Value
Connect To
Buffer Size
Buffer Type
Sets the buffer data type.
Direction
Sets the data direction flow of the component
Delay
Initial Delay Count
The initial delay that will be used at startup
Max Delay Count
The maximum number of values to delay the incoming signal by
Initial Value
Value used to preset the delay buffer.
Delay Calculation
Sample Rate (Hz)
Sample rate used to generate some useful calculations
Max Delay (s)
Maximum possible delay in seconds at the specified sample rate
Initial Delay (s)
Initial delay in seconds at the specified sample rate
