Component: Rectifier (DSP Operators)
Revision as of 11:49, 3 February 2023 by Wiki bot (talk | contribs)
Version 1.2
Category DSP Operators
Rectifier component
Converts the negative elements of a signal into a mirrored positive signal.
Please click here to download the component source project: FC_Comp_Source_DSP_Rectifier.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DSP_Rectifier.fcfx
ControlRectifier
ControlRectifier
Enables or disables the rectifier, enabled by default
- BOOL State
0=Disable, 1=Enable
Rectify
Rectify
Collects a single value from the input buffer and outputs a rectified version of the value.
RectifyArray
RectifyArray
Passes an entire buffer through the rectifier and outputs a rectified version of the buffer at the other end
Connect To
Buffer Size
Buffer Type
Sets the buffer data type.
Direction
Sets the data direction flow of the component
Rectifier
Rectifier Threshold
Value at which to choose to flip the signal. Default 0 for a signed buffer.
