Component: Actuators (BL0127) (E-blocks 2)
Version | 1.0 |
Category | E-blocks 2 |
- 1 Actuators component
- 2 Component Source Code
- 3 Detailed description
- 4 Examples
- 5 Macro reference
- 5.1 DCMotor_DC_Feedback
- 5.2 DCMotor_Reverse
- 5.3 Servo_MoveToPosition
- 5.4 DCMotor_Enable
- 5.5 Stepper_DisableMotor
- 5.6 Stepper_IncrementStep
- 5.7 Servo_EnableServo
- 5.8 Servo_SetAutoMoveSpeed
- 5.9 Servo_MoveToPositionInt
- 5.10 DCMotor_Coast
- 5.11 Servo_IsAutoMoving
- 5.12 Servo_IsServoAutoMoving
- 5.13 Stepper_DecrementStep
- 5.14 Servo_SetPositionInt
- 5.15 Servo_SetTrim
- 5.16 DCMotor_Break
- 5.17 Servo_Initialise
- 5.18 DCMotor_Forwards
- 5.19 Servo_SetAutoMoveSpeedInt
- 5.20 DCMotor_Disable
- 5.21 Stepper_EnableMotor
- 5.22 Servo_SetPosition
- 5.23 DCMotor_DC_FeedbackSim
- 5.24 Servo_AutoMoveToPosition
- 5.25 Servo_AutoMoveToPositionInt
- 5.26 Servo_DisableServo
- 6 Property reference
Actuators component
The Actuators board allows for investigation into several different motor types. Included on the board is a DC motor with both analogue and digital feedback, a servo motor and a stepper motor plus the circuitry to drive the motors.
Please click here to download the component source project: FC_Comp_Source_EBlocks2_Actuators_BL0127.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EBlocks2_Actuators_BL0127.fcfx
Sample program using the EBM020 - Infrared sensor.
Transmits a signal and determines distance from reflected value
DCMotor_DC_Feedback
DCMotor_DC_Feedback |
Return |
DCMotor_Reverse
DCMotor_Enable
DCMotor_Enable |
Enables the motor output | |
Return |
Stepper_DisableMotor |
Turn off the motor. It will no longer respond to any other macros. | |
Return |
Stepper_IncrementStep |
Move the motor forward by one step. | |
Return |
Servo_EnableServo
DCMotor_Coast
DCMotor_Coast |
Turn off power to the motor by setting the pins according to the 'Coast Pattern' property. | |
Return |
Servo_IsAutoMoving
Servo_IsAutoMoving |
Is the AutoMoveToPosition movement complete. Returns 1 if the servos are still moving. Returns 0 if all servo movement is complete. | |
Return |
Stepper_DecrementStep |
Move the motor backwards by one step. | |
Return |
Servo_SetTrim
DCMotor_Break
DCMotor_Break |
Actively drives both ends of the motor by setting the pins according to the 'Brake Pattern' property. | |
Return |
Servo_Initialise
Servo_Initialise |
Sets up the servo motor interrupts | |
Return |
DCMotor_Forwards
DCMotor_Disable
DCMotor_Disable |
Disable the motor output | |
Return |
Stepper_EnableMotor
Stepper_EnableMotor |
Turn on the motor. This must be done before it will respond to any other macros. | |
Return |
Servo_SetPosition
DCMotor_DC_FeedbackSim |
Return |
Servo_DisableServo
Servo_DisableServo |
Disables a servo channel effectivly disabling the motor. | |
Channel |
The channel to set the position for. First channel is zero. | |
Return |
