Component: GLCD (TLS8201) (Graphical Monochrome)
Revision as of 11:50, 3 February 2023 by Wiki bot (talk | contribs)
Version 1.3
Category Graphical Monochrome
GLCD (TLS8201) component
A Graphical LCD component to drive displays fitted with a TLS8201 controller IC.
Please click here to download the component source project: FC_Comp_Source_GLCD_TLS8201.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_TLS8201.fcfx
ReadFontWidth
ReadFontWidth
- BYTE Font
- BYTE Character
SetFontScaler
SetFontScaler
- BYTE ScaleX
- BYTE ScaleY
- INT Number
- UINT X
- UINT Y
- BYTE Font
- BYTE Transparent
DrawLine
DrawLine
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
Write_Data
Write_Data
- BYTE Data
DrawEllipse
DrawEllipse
- UINT X
- UINT Y
- UINT XRadius
- UINT YRadius
- BYTE Transparent
- BYTE Solid
Plot
Plot
- UINT X1
- UINT Y1
SetDisplayOrientation
- BYTE Orientation
BPlot
BPlot
- UINT X1
- UINT Y1
ReadFontStat
ReadFontStat
- BYTE Font
- BYTE Index
0=SpaceWidth, 1=PixelHeight
Print
Print
- STRING Str
- UINT X1
- UINT Y1
- BYTE Font
- BYTE Transparent
ClearDisplay
ClearDisplay
SetBackgroundColour
SetBackgroundColour
- BYTE Pixel_Colour
0=White, 1=Black
DrawCircle
DrawCircle
- UINT X
- UINT Y
- UINT Radius
- BYTE Transparent
- BYTE Solid
Write_Command
Write_Command
- BYTE Command
SetForegroundColour
SetForegroundColour
- BYTE Pixel_Colour
0=White, 1=Black
DrawRectangle
DrawRectangle
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
- BYTE Transparent
- BYTE Solid
Dimensions
Pixel Width
Pixel Height
Colour
Monochrome
Foreground Color
Background Colour
Bit Depth
Color Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
Data Pin
Data Pin Connection
Clock Pin
Clock Pin Connection
A0 Pin
A0 Pin Connection
CS Pin
Chip Select Pin Connection
Reset
Fonts
Font Count
Font 0
Font
Character Spacing
Space Width
Simulation Mode
Physical Orientation
