Component: Barometer (BME280) (Environmental)
| Version | 1.3 |
| Category | Environmental |
Barometer (BME280) component
A small PCB surface mount barometric pressure sensor with a I2C bus interface. Pressure range 300 to 1100 hPa. Temperature range -40 to +85 °C. Works with I2C interface only.
Please click here to download the component source project: FC_Comp_Source_Pressure_Sensor_BME280.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Pressure_Sensor_BME280.fcfx
BME280 Barometer plus Altitude v1.0
This example reads and displays the pressure, temperature & humidity.
If the pressure is increasing then Rise will be displayed.
Circuit Diagram
ReadPressureFloat
| ReadPressureFloat | |
| Reads the pressure as a floating point value in Bars. Calls the ReadPressureRaw function and then converts to a meaningful value. | |
Reset
| Reset | |
| Resets the device | |
I2C_Read_Register
| I2C_Read_Register | |
| Reads a byte value from a register on the device | |
| Address | |
ReadTemperatureFloat
Forced_Read
| Forced_Read | |
I2C_Write_Register
| I2C_Write_Register | |
| Writes a byte value to a register on the device | |
| Address | |
| Value | |
ReadHumidityFloat
| ReadHumidityFloat | |
| Reads the humidity as a floating point value in percentage 0-100%. Calls the ReadHumidityRaw function and then converts to a meaningful value. | |
Uninit
| Uninit | |
| Uninitialse and release I2C resources | |
| Starts up the I2C bus and initialises the pressure sensor ready for use. Returns 1 for a sucessful startup. Returns 0 for a failed startup or no device detected. | |
