Component: Robot Arm AllCode SIM (AllCode)
Revision as of 11:52, 3 February 2023 by Wiki bot (talk | contribs)
Category AllCode
Robot Arm AllCode SIM component
Matrix 5-axis Robot Arm with Gripper. Compatible with the Matrix Robot ARM Training Curriculum and Hardware. Features gripper pressure sensor, light sensor, colour sensor, Potentiometer, Magnetic sensor.
Please click here to download the component source project: FC_Comp_Source_RA_Simulation_Source.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_RA_Simulation_Source.fcfx
Industrial Tanks
A simple example showing the hoppers, valves and pipes working together. Each tank automatically empties in turn.
FC6 Icon.png Industrial Tanks
LEDOn
Fc9-comp-macro.png LEDOn
Switches on a single LED, LA0-LA7
Fc9-u8-icon.png - BYTE Index
0=LA0, 1=LA1, 2=LA2, 3=LA3, 4=LA4, 5=LA5, 6=LA6, 7=LA7
StoreCoords
Fc9-comp-macro.png StoreCoords
Stores the provided coordinates as a position the ARM can recall.
Save Index - Range 0-29
Fc9-u8-icon.png - BYTE Position0
Range: 0-180
Fc9-u8-icon.png - BYTE Position1
Range: 0-180
Fc9-u8-icon.png - BYTE Position2
Range: 0-180
Fc9-u8-icon.png - BYTE Position3
Range: 0-180
Fc9-u8-icon.png - BYTE Position4
Range: 0-180
LCDClearLine
Fc9-comp-macro.png LCDClearLine
Fc9-u8-icon.png - BYTE Line
The line to clear, zero being the first (top) line of the display
LEDOff
Fc9-comp-macro.png LEDOff
Switches off a single LED, LA0-LA7
SetMovementSpeed
Fc9-comp-macro.png SetMovementSpeed
Controls the speed of the robot movement
Fc9-u8-icon.png - BYTE MovementSpeed
1=Normal Speed (Default), 2=DoubleSpeed
LEDWrite
Fc9-comp-macro.png LEDWrite
Allows a value to be sent to control all eight LEDs LA0-LA7 at once
Fc9-u8-icon.png - BYTE Value
(0-63) 0b000000
LinearInterpolation
Fc9-comp-macro.png LinearInterpolation
Moves the robot to the new position so that all axis arrive at the same time.
Fc9-u8-icon.png - BYTE pos0
Fc9-u8-icon.png - BYTE pos1
Fc9-u8-icon.png - BYTE pos2
Fc9-u8-icon.png - BYTE pos3
Fc9-u8-icon.png - BYTE pos4
GripperOpen
Fc9-comp-macro.png GripperOpen
Fully opens the gripper at the end of the arm ready to pick something up.
ReadSwitch
Fc9-comp-macro.png ReadSwitch
Read the value of a single switch. Returns the value as a byte
Fc9-u8-icon.png - BYTE index
0=SA0, 1=SA1, 2=SA2, 3=SA3, 4=SA4, 5=SA5, 6=SA6, 7=SA7
LCDPrintStr
Fc9-comp-macro.png LCDPrintStr
Fc9-string-icon.png - STRING PrintString
Enter the text or variable to print to the LCD
SetAllServos
Fc9-comp-macro.png SetAllServos
Move all the servo positions between 0-180 Deg
Fc9-u8-icon.png - BYTE Servo0_Base
Position of servo0 in degrees (0-180)
Fc9-u8-icon.png - BYTE Servo1_Shoulder
Position of servo1 in degrees (0-180)
Fc9-u8-icon.png - BYTE Servo2_Elbow
Position of servo2 in degrees (0-180)
Fc9-u8-icon.png - BYTE Servo3_Wrist
Position of servo3 in degrees (0-180)
Fc9-u8-icon.png - BYTE Servo4_WristRotate
Position of servo4 in degrees (0-180)
Park
Fc9-comp-macro.png Park
Parks the Robot ARM and switches off the servo motors
StorePosition
Fc9-comp-macro.png StorePosition
Stores the current position of the ARMs 5 axis.
ReadPressure
Fc9-comp-macro.png ReadPressure
Read the value of the pressure sensor on the ARM gripper. Returns the value as a byte
GotoPosition
Fc9-comp-macro.png GotoPosition
Recalls a previously saved position for the ARMs 5 axis.
MotorsMoving
Fc9-comp-macro.png MotorsMoving
Checks to see if any of the motors are still moving.
Beep
Fc9-comp-macro.png Beep
Allows the beeper to output a warning
Fc9-u8-icon.png - BYTE Iterations
Fc9-u16-icon.png - UINT OnDelay
Delay in ms
Fc9-u16-icon.png - UINT OffDelay
Delay in ms
SetTrim
Fc9-comp-macro.png SetTrim
Allows minor adjustment on the 5 axis servo motors
Motor Index Range 0-4
Fc9-u8-icon.png - BYTE Trim
Amount of Trim Range 0-255, Default Value 128
SetServo
Fc9-comp-macro.png SetServo
Move the specified servo motor position between 0-180 Deg
Range 0-4 : 0=Base, 1=Shoulder, 2=Elbow, 3=Wrist, 4=WristRotate
Position of servo in degrees (0-180)
GripperClose
Fc9-comp-macro.png GripperClose
Fully closes the gripper at the end of the arm ready to pick something up. Closes to a defined pressure using the built in pressure sensor. Returns 0 if nothing detected in the gripper Returns 1 if a valid object is detected
Fc9-u8-icon.png - BYTE Pressure
Range 1 - 100, Default Pressure = 20
LCDCursor
Fc9-comp-macro.png LCDCursor
Fc9-u8-icon.png - BYTE X
Set the cursor position in the X plane, 0 is the left most cell (0-15)
Fc9-u8-icon.png - BYTE Y
Set the cursor position in the Y plane, 0 is the top most cell (0-1)
LCDPrintNum
Fc9-comp-macro.png LCDPrintNum
Will allow you to print a number. This is limited to a signed-INT, -32768 to 32767
Fc9-s16-icon.png - INT Number
LCDClear
Fc9-type-16-icon.png Starting Conditions
