Component: PIC32 Core Timer (Timing)
Revision as of 11:52, 3 February 2023 by Wiki bot (talk | contribs)
Author MatrixTSL
Category Timing
PIC32 Core Timer component
Allows for easy and accurate timings using the built in Core timer on the PIC32 devices.
Please click here to download the component source project: FC_Comp_Source_TimerComponentPIC32Core.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_TimerComponentPIC32Core.fcfx
Start_S
Fc9-comp-macro.png Start_S
A none blocking function that allows for accurate delays to be specified in seconds using the core timer.
Fc9-u32-icon.png - ULONG Delay
Start_InstructionCount
Fc9-comp-macro.png Start_InstructionCount
A none blocking function that allows for accurate delays to be specified in FOSC instructions using the core timer.
Delay_S
Fc9-comp-macro.png Delay_S
A blocking function that allows for accurate delays to be specified in seconds using the core timer.
Start_Ms
Fc9-comp-macro.png Start_Ms
A none blocking function that allows for accurate delays to be specified in milliseconds using the core timer.
Start_Us
Fc9-comp-macro.png Start_Us
A none blocking function that allows for accurate delays to be specified in micro seconds using the core timer.
Delay_Ms
Fc9-comp-macro.png Delay_Ms
A blocking function that allows for accurate delays to be specified in milliseconds using the core timer.
Delay_InstructionCount
Fc9-comp-macro.png Delay_InstructionCount
A blocking function that allows for accurate delays to be specified in FOSC instructions using the core timer.
Start_Ns
Fc9-comp-macro.png Start_Ns
A none blocking function that allows for accurate delays to be specified in nano seconds using the core timer.
Delay_Us
Fc9-comp-macro.png Delay_Us
A blocking function that allows for accurate delays to be specified in micro seconds using the core timer.
Delay_Ns
Fc9-comp-macro.png Delay_Ns
A blocking function that allows for accurate delays to be specified in nano seconds using the core timer.
Check_Counter
Fc9-comp-macro.png Check_Counter
Checks to see if the counter time is elapsed. Used in conjunction with the Start_ component macros. Returns 1 if complete or 0 if still counting.
