| Author
Matrix Ltd.
| Version
1.5
| Category
Wireless
Zigbee (EB051, XBEE) component
Zigbee component designed to work with the XBEE range of modules from Digi. Provides a very simple interface to allow Zigbee mesh networks and communications. Also available in the form of the EB051 Zigbee E-block. Can also be used with Zigbee MIAC Addon module
Please click here to download the component source project: FC_Comp_Source_Zigbee.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Zigbee.fcfx
NodeConfigureSleep
| Sets the Zigbee device sleep mode (only applicable for end node type devices) ,
- BYTE
Mode
| 1=Hibernate, 2=Doze, 4=Cyclic Sleep, 5=Cyclic Doze
- UINT
Timeout
| Time to sleep in milli seconds (ms)
ReadNameFromBuffer
ReadNameFromBuffer
| Returns a byte from the 8-Byte name
- BYTE
Device
| The Device name to collect. Range: 0-7
- BYTE
Idx
| The index position of the name. Range: 0-7
- BYTE
NodeWake
NodeWake
| Wakes up the local Zigbee module from sleep mode.
ReadATResponse
ReadATResponse
| Reads a single byte from the received AT command response.
- BYTE
idx
| Specified the byte index in the buffer. Range 0-15
- BYTE
ScanBuffer
ScanBuffer
| Returns a binary list of matched identifier names
- STRING
Compare_Str
- BYTE
Length
- BYTE
SendChar
SendChar
| Transmits a byte value to the Zigbee module.
- BYTE
Byte
| Data byte to transmit. Range 0-255
InitNetwork
InitNetwork
| Initialises the Zigbee module and attempts to setup or join the network
ConnectToCoordinator
| Attempts to connect the data channel to the network coordinator node.
- BYTE
MIAC_Module_GetData
MIAC_Module_GetData
- BYTE
Index
- BYTE
ConnectToName
ConnectToName
| Attempts to connect the data channel to a named device on the network.
- STRING
Name
- BYTE
StoreParams
StoreParams
| Stores the current register set into the Zigbee module's non volatile memory
EnterCommandMode
EnterCommandMode
| Moves from data mode into command mode by sending the special characters
RestartNetwork
RestartNetwork
| Attempts to restart the network
MIAC_Module_Message
MIAC_Module_Message
- UINT
CAN_ID
- UINT
CMD_ID
- BYTE
ConnectToAll
ConnectToAll
| Attempts to connect the data channel to all devices on the network.
- BYTE
ConnectFromLibrary
ConnectFromLibrary
| Attempts to connect the data channel to a known device on the network.
- BYTE
Mode
- BYTE
Device
- BYTE
ConnectToAddress
ConnectToAddress
| Attempts to connect the data channel to a specific device address on the network.
- STRING
Address
- BYTE
GetSignalLevel
GetSignalLevel
| Returns the signal strength of the last signal received
- BYTE
ExitCommandMode
ExitCommandMode
| Returns from command mode to allow data to be sent and received
MIAC_Module_PushData
- BYTE
Data
ReadAddressFromBuffer
| Reads a byte from a 16-bit Zigbee device address
- BYTE
Device
- BYTE
Idx
- BYTE
SendATCommand
SendATCommand
| Transmits a string of values to the Zigbee module.
- STRING
Command
| Transmits a command to the Zigbee module followed by a carriage return
ScanNetwork
ScanNetwork
| Scans the local network for devices and stores into a local device array. Mode = 0 store device names, mode = 1 store device addresses. Returns the number of devices found.
- BYTE
Mode
- BYTE
GetATResponse
GetATResponse
| Waits for a response from the Zigbee module. If the Logging parameter is set then the response is stored in memory allowing the software to read the reply.
- BYTE
Logging
- BYTE
ReceiveChar
ReceiveChar
| Attempt to receive a byte from the Zigbee module.
- BYTE
nTimeout
- BYTE
Device Name
| String of characters used to allow the Zigbee node to use the name addressing mode of operation. Can be left blank if name addressing is not being used.
Zigbee Mode
| Specifies the functionality of the Zigbee node. Coordinator - Must be used with a Coordinator Zigbee E-Block EB051C, Responsible for starting the network and assigning addresses. Router - Must be used with a Router / End Node E-Block EB051R, Responsible for forwarding / repeating packets on the network. End Device - Must be used with a Router / End Node E-Block EB051R, Capable of low power operation.
Auto ID
| Automatically generate a PAN ID
PAN ID
| Assigns a Personal Area Network Identifier code to the Zigbee node. Random / Search - Scans the local area for Zigbee PAN networks and joins the existing network, otherwise a random value is chosen. Preset - Assigns a preset PAN ID to the Zigbee node, Must be between 0x0 and 0x3FFF.
Node Join Time
| Length of time in seconds where nodes are allowed to join the network. Infinte - Nodes are always allowed to join the network. Preset - Nodes are only allowed to join the network for a specific amount of time. Note: Join time not available for End Device nodes.
Max Hops
| Specifies the maximum number of retransmits for a Broadcast transmission.
Sleep Buffer Time
| Length of time to buffer packets for sleeping or powered down nodes. This value must be consistent throughout the Zigbee network. Default - Assigns the maximum buffer time of 28 seconds. Preset - Allows for a custom sleep time of 0.32 - 28 seconds.
| UART Channel selector Software channels are bit banged using generic I/O pins but are not as reliable as hardware channels. Hardware channels use the selected peripheral on-board the target microcontroller.
TX
| Pin to be used for Transmit data
RX
| Pin to be used for Receive data
Baud Options
| Baud rate option selector
Use Flow Control
| Flow Control (Handshake) enable or disable. On: Two I/O pins are used to control the flow of data in and out of the device. Off: Flow control is disabled.
RTS
| Pin to be used for Request To Send handshake function Output from target micro to inform remote device we are ready to receive data. Low = Ready to receive data High = Not ready to receive data
CTS
| Pin to be used for Clear To Send handshake function. Input to target micro to inform when the remote device is ready to transmit data. Low = Ready to transmit data High = Not ready to transmit data
Sleep Pin
| Zigbee Sleep Control Pin
Scan Channels
0x0B
| Determines if channel will be scanned
0x0C
0x0D
0x0E
0x0F
0x10
0x11
0x12
0x13
0x14
0x15
0x16
0x17
0x18
0x19
0x1A
Scan Duration
| Configures the length of time to scan each channel for network activity. The overall time for the entire channel scan is shown as channel scan time.
Total Scan Time (ms)
| The total amount of time that it will take to perform a complete RF channel scan based on the selected scan channels and duration.
| Selects if the scope traces are automatically added to the data recorder window or not. Simulation - draws an approximation of the UART data onto the scope trace. ICT - sets up the scope trace for incoming data and adds UART packet decoding at the correct BAUD.
Console Columns
| Number of characters that can be displayed on a single line of the console.
Data Source
| Simulation data source used to allow the component to connect to various remote devices Nothing - Simulation data is ignored COM port - Routes the communication data to and from a physical or virtual COM port API - Routes the communication data via a data API component on the Panel.
