Component: Dash Scale Vertical ()
Revision as of 12:00, 3 February 2023 by Wiki bot (talk | contribs)
Version 1.3
Category
Dash Scale Vertical component
Vertical based slider with a user defined scale, typically used on in SCADA based solution
Please click here to download the component source project: FC_Comp_Source_temp/Dashboard_Scale_Vertical.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/Dashboard_Scale_Vertical.fcfx
Function
Decide whether the scale should be a control that interacts with the mouse, or just a passive display.
Maximum
The maximum value displayed on the scale (top of the component)
Minimum
The smallest value visible on the scale (bottom of the component)
Style
BG Color
Colour of the display background.
Positive Color
Colour for the scale marking above zero.
Negative Color
Colour of the display markings below zero.
Label Color
Colour of the component label.
Bezel
Colour of the bezel (3D border)
Resolution
Amount of detail in the display markings.
Marks
Divisions
The number of major divisions of the arc. These can have numbered labels.
Subdivisions
The number of minor sub-divisions between each major division.
Numbers
Decimals
Number of decimal places to show for the number labels.
Text Size %
Size of the number label text. (percentage of the component wdith)
Font
Font to use for the number labels.
Text
Set the text to be displayed in the components name label.
Text Size %
Size of the name label text (percentage of the component width)
Font
The font to use for the component name label.l
