Component: Thermistor (EBM003) (EBM Modules)
| Version | 1.1 |
| Category | EBM Modules |
Thermistor component
A generic thermistor component that can be used to simulate and create code for any thermistor with a known temperature/resistance curve. Thermistor is connected in a simple potential divider circuit - thermistor between ADC input and 0V, and a fixed resistor between ADC and the positive supply. The component is also used with the EBM003 module, in which case the extra circuitry is already included. Default calibration is for the EBM003 module.
Please click here to download the component source project: FC_Comp_Source_temp/EBM003v1.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/EBM003v1.fcfx
CalculateTemperature
|   | CalculateTemperature |
| Converts the input ADC value and returns the Temperature in tenths of degree C | |
|  - UINT | ADCValue |
| ADC Reading to be converted | |
|  - INT | Return |
GetADCValue
|   | GetADCValue |
| Returns the Raw ADC value from the Analogue Channel | |
|  - UINT | Return |
GetIntegerTemperature
|   | GetIntegerTemperature |
| Reads the ADC input and returns the calculated Temperature as Integer degrees C | |
|  - INT | Return |
GetRealTemperature
|   | GetRealTemperature |
| Reads the ADC input and Returns the calculated Temperature as Float value in degrees C | |
|  - FLOAT | Return |
SetChannel
|   | SetChannel |
| Set the ADC Channel | |
|  - INT | ChannelID |
|  - VOID | Return |
SetTemperature
