Component: EBM004 GUI (Misc)
Revision as of 12:00, 3 February 2023 by Wiki bot (talk | contribs)
Author Matrix
Category Misc
EBM004_GUI component
Private non-release sub-component for the EBM004 digital temperature sensor.
Please click here to download the component source project: FC_Comp_Source_temp/EBM004_GUI.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/EBM004_GUI.fcfx
ReadByte
Fc9-comp-macro.png ReadByte
Get the data from the MSB of a sensor register.
The address of the byte to return.
ReadFloat
Fc9-comp-macro.png ReadFloat
Get the temperature register value converted into an actual floating point temperature readng in Celcius.
ReadInt
Fc9-comp-macro.png ReadInt
Get the complete 16bit integer value of the sensor's temperature register.
Fc9-s16-icon.png - INT Return
SetConsoleHandle
Fc9-comp-macro.png SetConsoleHandle
Pass the parent sensor's console handle to the GUI to allow opening of the console from the 'Console' button.
Fc9-h32-icon.png - HANDLE Handle
Handle of the console
SetMinMax
Fc9-comp-macro.png SetMinMax
Set the minimum and maximum temperature values that can be shown and set on the thermometer readout.
Fc9-f32-icon.png - FLOAT Min
Minimum Value
Fc9-f32-icon.png - FLOAT Max
Maximum Value
SetTemperature
Fc9-comp-macro.png SetTemperature
Sends the given temperature to the display, and calculates the internal values used by the simulated read macros.
Fc9-f32-icon.png - FLOAT Temperature
Zero to one value - representing min-max of the sensor.
Fc9-conn-icon.png Simulation
Fc9-type-10-icon.png Label
A text label to help you identify the component on the panel.
Fc9-type-15-icon.png Min. Temp.
Minimum termperature that can be set or displayed on the thermometer slider.
Fc9-type-15-icon.png Max. Temp.
Maximum termperature that can be set or displayed on the thermometer slider.
Fc9-type-21-icon.png Scale divisions
Number of numbered divisions shown on the thermometer scale.
Fc9-type-16-icon.png I2C Data
Choose whether the I2C data is shown as decimal or hexadecimal values.
