| Author
MatrixTSL
| Version
1.0
| Category
Analog Input
ADC (MCP356X) component
An external ADC featuring 2, 4, or 8 channel 24-bit input. Capable of reading each channel independently or in differential mode. Communication using an SPI bus up to 20MHz.
Please click here to download the component source project: FC_Comp_Source_temp/ExternalADC_MCP356X.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/ExternalADC_MCP356X.fcfx
| Confgures the SPI bus ready for communications and initialises the MCP356X device. Returns true if device is responding to commands.
- BOOL
SampleADC
SampleADC
| Performs a single ADC sample and returns the result as a 24-bit value
- BYTE
PositiveChannel
| 0=CH0 - 7=CH7, 8=GND, 9=VDD, 11=REF+, 12=REF-, 13=TP, 14=TM, 15=VCM
- BYTE
NegativeChannel
- LONG
SetGainCalibration
SetGainCalibration
| Allows the device offset to be entered allowing for accurate readings.
- ULONG
Gain
| Default 800000 = Gain of 1X
SetOffsetCalibration
- LONG
Offset
Device Configuration
Device Type
Device Address
| These bits are fixed from the manufacturer and by default are 01. Used as Bits 6 and 7 of the command byte. Alternative bits must be requested from the manufacturer.
Clock Selection
Sensor Bias Current
ADC Bias Current
AMCLK Prescaler
Oversampling Ratio
ADC Gain
IRQ Mode
| SPI Channel selector
Prescale
| Prescale option selector
MOSI
MOSI Remap Pin
| Select which the target pin to assign the MOSI hardware pin functionality.
MISO
MISO Remap Pin
| Select which the target pin to assign the MISO hardware pin functionality.
CLK
CLK Remap Pin
| Select which the target pin to assign the CLK hardware pin functionality.
CS / SS
| Chip Select / Slave Select Pin Master Mode: General purpose output pin used to select the remote SPI device. Slave Mode: Hardware chip select pin input used to select the SPI device.
Use IRQ
| No: Use polling of the status register to determine when an ADC sample is complete. Yes: Use the IRQ interrupt pin to determine when an ADC sample is complete.
Simulate Comms
| No: Simulation is done using panel sliders. Yes: Send SPI data via API interface and show real time data using panel sliders.
