Component: GameCode (Misc Circuit)
Revision as of 12:01, 3 February 2023 by Wiki bot (talk | contribs)
Author Jef De Bruyne
Category Misc Circuit
GameCode component
A small handheld device designed for creating embedded games. Complete with a 8 x 16 LED display, 4-Way DPAD with 4 additional push switches Buzzer, Vibration, MP3 Player, Potentiometer and Lithium battery management. Programmed via USB.
Please click here to download the component source project: FC_Comp_Source_temp/GameCode_Master.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/GameCode_Master.fcfx
FC6 Icon.png GSM Example Example should show the following on the display on the panel and on the hardware.
The AT injector component allows us to simulate the response of the GSM module.
BatteryRead
Fc9-comp-macro.png BatteryRead
Read and return the voltage level of the battery in millivolt.
DisplayBrightness
Fc9-comp-macro.png DisplayBrightness
Control the brightness of the display.
Fc9-u8-icon.png - BYTE Value
Enter value from 0 to 15
DisplayClear
Fc9-comp-macro.png DisplayClear
Clear the display.
DisplayWrite
Fc9-comp-macro.png DisplayWrite
Write an array containing 16 bytes to the display to illuminate the corresponding dots. The index represents the line (Y-axis), starting from 0 for the uppermost line. The value of the byte represents the column (X-axis), with MSB the leftmost dot.
Fc9-u8-icon.png - BYTE Array
Index = line, Content (byte) = column
DisplayWriteNumber
Fc9-comp-macro.png DisplayWriteNumber
Show a number ranging from 000 to 999 on the display. Number is printed vertically.
Fc9-u16-icon.png - UINT Value
Enter a number from 0 to 999.
EEReadValue
Fc9-comp-macro.png EEReadValue
Retreives a value from none volitile memory
Address to write to, Range: 0-255
EEStoreValue
Fc9-comp-macro.png EEStoreValue
Saves a value to none volitile memory
Value to store, Range: 0-255
Fc9-comp-macro.png Initialise
Initializes all present hardware and communication. Place this at the very start of your code.
LedsWrite
Fc9-comp-macro.png LedsWrite
Set the button-leds. MSB = leftmost led LSB = rightmost led
MSB = leftmost dot, LSB = rightmost dot
MP3GetStatus
Fc9-comp-macro.png MP3GetStatus
Returns the status of the MP3 module. 0 = module in sleep 1 = track is playing 2 = track is pauzed 3 = track is stopped
MP3PausePlayResetStop
Fc9-comp-macro.png MP3PausePlayResetStop
Allows the current playing track to be paused, restarted or stopped.
Fc9-u8-icon.png - BYTE Mode
0=Pause, 1=Play, 2=Reset, 3=Stop
MP3PlayTrack
Fc9-comp-macro.png MP3PlayTrack
Plays track from the selected folder. MP3 & Advert folder track numbers should be 4 characters long e.g. "0001-anyname.mp3". Other folder track numbers should be 3 characters long e.g. "001-anyname.mp3".
Fc9-u8-icon.png - BYTE Directory
0=Root, 01=Folder "01" - 99=Folder "99", 100=Folder "MP3", 101=Advert
Fc9-u16-icon.png - UINT Track
Track number 1 = "001.mp3" / "0001.mp3"
MP3SendCommand
Fc9-comp-macro.png MP3SendCommand
Send commands to MP3 module. Check datasheet for info.
Fc9-u8-icon.png - BYTE Command
Fc9-u8-icon.png - BYTE Para1
Fc9-u8-icon.png - BYTE Para2
MP3SetVolume
Fc9-comp-macro.png MP3SetVolume
Sets the volume level for the MP3 module
Fc9-u8-icon.png - BYTE Volume
Range: 0 (min) - 30 (max)
PlayNote
Fc9-comp-macro.png PlayNote
Output a single note on the buzzer. Specify the desired frequency (Hz) and duration (ms).
Fc9-u16-icon.png - UINT Frequency
Sets the pitch for the note in Hz. Range 1-20000 Hz
Fc9-u32-icon.png - ULONG Duration
Time period to play the note for in milliseconds. Range 0-65535 ms
PotRead
Fc9-comp-macro.png PotRead
Read and return the value of the potentiometer. If desired, give the upper limit to scale the output value. Enter "MaxValue = 0" to skip scaling and get the byte value (0-255)
Fc9-u16-icon.png - UINT MaxValue
Scale the return value. Enter 0 to skip.
PwrLedSet
Fc9-comp-macro.png PwrLedSet
Control the PWR LED. 0 = red + green 1 = red 2 = green
0 = red + green, 1 = red, 2 = green
Fc9-conn-icon.png LED Colours
Fc9-type-1-icon.png LED On
Fc9-type-1-icon.png LED Off
Fc9-conn-icon.png Display Colours
Fc9-type-1-icon.png On Colour
Fc9-type-1-icon.png Off Colour
