Component: Temp / Humidity (SHT31) (Environmental)
Revision as of 12:01, 3 February 2023 by Wiki bot (talk | contribs)
Version 2.0
Category Environmental
Temp / Humidity (SHT31) component
Humidity and temperature sensor using an SHT31 IC connected via I2C. On screen GUI allows temperature and humidity values to be simulated, and will show all I2C communication in a console window.
Please click here to download the component source project: FC_Comp_Source_temp/Humidity_SHT31.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/Humidity_SHT31.fcfx
GetHumidityData
Fc9-comp-macro.png GetHumidityData
Returns the raw register pair value
GetHumidityInt
Fc9-comp-macro.png GetHumidityInt
returns the relative Humidity reading as an integer value
Fc9-s16-icon.png - INT Return
GetHumidityReal
Fc9-comp-macro.png GetHumidityReal
returns the Humidity reading as a float value
GetTemperatureData
Fc9-comp-macro.png GetTemperatureData
GetTemperatureInt
Fc9-comp-macro.png GetTemperatureInt
Return temperature reading as an integer value in degrees C
GetTemperatureReal
Fc9-comp-macro.png GetTemperatureReal
Return temperature reading as a float value in degrees C
Fc9-comp-macro.png Initialise
Configures the I2C peripheral and puts the sensor into one shot mode ready to be sampled. Must be called before calling any of the other component macros. Returns 1 if the sensor has been intialised correctly, else returns 0.
Fc9-type-16-icon.png Address
Selects the correct device address based on the ADDR pin connection to VDD or VSS.
Fc9-type-16-icon.png Channel
Channel selection
Fc9-type-5-icon.png SDA
Fc9-type-5-icon.png SCL
Baud rate to be used
Fc9-conn-icon.png Simulation
Fc9-type-7-icon.png Simulation Comms
