Component: I2C (CAL) (Misc)
Revision as of 12:01, 3 February 2023 by Wiki bot (talk | contribs)
Version 2.0
Category Misc
I2C component
CAL = Code Abstraction Layer - Allows one code base to run on a wide range of chips. A low level implementation giving direct access to the Two Wire I²C peripheral.
Please click here to download the component source project: FC_Comp_Source_temp/I2C.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/I2C.fcfx
GetConsoleHandle
Obtains the CAL console handle
GetList
Fc9-comp-macro.png GetList
returns Named property List as filter string
Fc9-string-icon.png - STRING Name
GetValue
Fc9-comp-macro.png GetValue
Get the Named property value.
Master_Init
Fc9-comp-macro.png Master_Init
Initialise the Master
Master_Restart
Fc9-comp-macro.png Master_Restart
Output a Master Restart sequence
Master_RxByte
Fc9-comp-macro.png Master_RxByte
Returns a received data byte. Set Last=0 if there is following more Master_RxByte macros Set Last=1 if this is the last Master_RxByte and it is followed with Master_Stop. If Last = 1 the I2C bus will be presented with a 'Nack' condition.
Fc9-u8-icon.png - BYTE Last
Range: 0-1 - 0 = Not the last byte to receive, 1 = last byte to receive
Master_Start
Fc9-comp-macro.png Master_Start
Output a Master Start sequence
Master_Stop
Fc9-comp-macro.png Master_Stop
Output a Master Stop
Master_TxByte
Fc9-comp-macro.png Master_TxByte
Send a data byte and collects the acknowledge from the slave. Returns 0 for Ack received. Returns 1 for Ack not received - slave not responding.
Fc9-u8-icon.png - BYTE Data
Data byte to write to the I2C bus
Master_Uninit
Fc9-comp-macro.png Master_Uninit
Uninitialise the Master
SetValue
Fc9-comp-macro.png SetValue
Change Named property to new Value. If "CHANNEL" the ports will be also updated from the fcd
Fc9-string-icon.png - STRING Value
port value as string
Slave_Init
Fc9-comp-macro.png Slave_Init
Initialise the Slave with the given Address, or range of Addresses. Only address bits that have a corresponding bit set in the Mask will be compared with the incoming bus address.
7 Bit Address of this device (Bit 0 is ignored)
Fc9-u8-icon.png - BYTE Mask
Bit mask used to compare addresses
Slave_RxByte
Fc9-comp-macro.png Slave_RxByte
Returns the data received, and sends either Ack or Nak Set parameter Last as: 1=Last=Nak, 0=Ack=More
Sends Ack if 0, else Nak
Slave_Status
Fc9-comp-macro.png Slave_Status
Returns the Slave Status. Bit 0 = 1 Indicates address/data byte available in the buffer to read Bit 5 = 1 Indicates that the last byte received or transmitted was data (else address)
Slave_TxByte
Fc9-comp-macro.png Slave_TxByte
Send a data byte, returns Ack/Nak from Master 0=Ack=More, 1=Nak=Last
Slave_Uninit
Fc9-comp-macro.png Slave_Uninit
Uninitialise the Slave
Transaction_Initialise
Fc9-comp-macro.png Transaction_Initialise
Initialise the I2C interface to communicate with a Slave device at Address Returns 0 on fail, 1 on success
7-bit I2C Address without the shift for the R/W bit
Transaction_Read
Fc9-comp-macro.png Transaction_Read
Attempt to read Length number of bytes from the I2C slave to the given Buffer. Ensure that the Buffer is large enough. Returns number of bytes read, caller should check that this matches requested Length
Fc9-u8-icon.png - BYTE Buffer
Buffer to store the incoming byte data
Number of bytes to read
Transaction_Uninit
Fc9-comp-macro.png Transaction_Uninit
Uninitialise the I2C interface
Transaction_Write
Fc9-comp-macro.png Transaction_Write
Attempt to write Length number of bytes to the I2C slave from the given Buffer. Ensure that the Buffer is large enough. Returns the number of bytes written, the caller should check that this matches requested Length
Buffer of bytes to write to the I2C
Fc9-type-7-icon.png Component Enable
Allows the component to be easily disabled from generating code, allowing for multiple CAL components to be easily created. For example a sensor IC with both I2C and SPI communications interfaces.
Fc9-type-16-icon.png Channel
Channel selection
Fc9-type-16-icon.png Mode
Defines if the component will be used for Master or Slave communications. Master mode supports a software bitbanged I2C channel. Slave mode requires a hardware I2C peripheral to catch the communications from the Master.
Fc9-type-5-icon.png SDA
Fc9-type-5-icon.png SCL
Fc9-conn-icon.png Options
Baud rate to be used
Fc9-type-16-icon.png Slew Rate Control
Slew Rate Control Enabled or Disabled
Fc9-type-16-icon.png SMBus Inputs
When Enabled input logic thresholds are compliant with SMBus specification
Fc9-conn-icon.png Simulation
Fc9-type-16-icon.png API
Specifies the API component on the panel to interact with to provide comms simulation.
