Component: Injector (File) (Test Injectors)
Revision as of 12:01, 3 February 2023 by Wiki bot (talk | contribs)
Category Test Injectors
Injector (File) component
Comms data injector to allow data to be streamed to and from a file during simulation. The component will read data from the incoming file and write data to the outgoing file.
Please click here to download the component source project: FC_Comp_Source_temp/InjectorFile.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/InjectorFile.fcfx
Example to log the bytes sent via the UART RS232 component to a file as comma separated decimal numbers. FC6 Icon.png LogToFile Contents of the file in the Flowcode project directory after running the simulation.
SPIInitialise
Fc9-comp-macro.png SPIInitialise
SPIPrescaler
Fc9-comp-macro.png SPIPrescaler
Range: 0-2
SPITransfer
Fc9-comp-macro.png SPITransfer
SPITransferTrans
Fc9-comp-macro.png SPITransferTrans
Fc9-u16-icon.png - UINT Count
Outgoing data
Fc9-u8-icon.png - BYTE DataIn
Incoming data
UARTBaud
Fc9-comp-macro.png UARTBaud
Fc9-u8-icon.png - BYTE Rate
UARTCheckRX
Fc9-comp-macro.png UARTCheckRX
UARTInitialise
Fc9-comp-macro.png UARTInitialise
UARTReceive
UARTSend
Fc9-comp-macro.png UARTSend
Fc9-type-7-icon.png Show Console
Fc9-conn-icon.png Incoming File Settings (Rx)
Fc9-type-13-icon.png Incoming File
File to stream incoming data from. File -> Communications component.
Fc9-type-16-icon.png Parse Mode
Specifies the way we read in the data from the file. Detailed Byte : "z - 122 - 0x7a" Raw : "z" CSV Decimal : "122, " CSV Hex : "0x7a, "
Fc9-type-16-icon.png Display Mode
Specifies the way we show the data on the console. Detailed Byte : "z - 122 - 0x7a" Raw : "z" CSV Decimal : "122, " CSV Hex : "0x7a, "
Fc9-type-21-icon.png Values Per Line
Number of values to display on a single line of the data console. 0 = Infinite number of characters
Fc9-type-7-icon.png Skip Timestamp
A file populated with data from an injector may have a timestamp built in which we may not want to receive. Yes: Skip first 22 characters of each line of data so we don't receive any of the timestamp info. No: Read data normally.
Fc9-conn-icon.png Outgoing File Settings (Tx)
Fc9-type-13-icon.png Outgoing File
File to store outgoing data. Communications component -> File
Fc9-type-7-icon.png Clear On Init
No - Append to the end of the file. Yes - Empty file on initialise and start from the beginning of the file.
Fc9-type-16-icon.png Data Mode
Specifies how the data is represented in the outgoing file. Detailed Byte : "z - 122 - 0x7a" Raw : "z" CSV Decimal : "122, " CSV Hex : "0x7a, "
Number of values to display on a single line, applies to the file and data console. 0 = Infinite number of characters
Fc9-type-7-icon.png Append Timestamp
Appends a timestamp to the beginning of every line relating to the time the first byte in the line was received. Based on the PC system time. Timestamp in the format "YY/MM/DD - HH:MM:SS - "
