Author
Matrix TSL
Version
1.1
Category
E-blocks 1
LCD component
LCD based on the unit used in the Matrix EB005 E-block
Please click here to download the component source project: FC_Comp_Source_temp/LCD_EB005.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/LCD_EB005.fcfx
Example of a typical LCD pinout.
For the LCDs to work with the Flowcode LCD component they need to be connected up in 4-bit data mode.
The 4 data signals actually go to the upper data nibble on the LCD as shown below.
A simple example that shows how to use some common functions.
LCD Example
Clear
Clear
ClearLine
ClearLine
- BYTE
Line
The line to clear, zero being the first (top) line of the display
Command
Command
- BYTE
instruction
Send a defined command to the LCD Screen. See datasheet for supported commands.
Cursor
Cursor
- BYTE
x
Set the cursor position in the X plane, 0 is the left most cell
- BYTE
y
Set the cursor position in the Y plane, 0 is the top most cell
PrintAscii
PrintAscii
- BYTE
character
Holds an ascii value.
PrintFormattedNumber
- ULONG
Number
- BOOL
Format
0=Signed, 1=Unsigned
Based on v5 macro, will allow you to print a number. This is limited to a signed-INT, -32768 to 32767
- INT
Number
PrintString
PrintString
- STRING
Text
Enter the text or variable to print to the LCD
RAMWrite
RAMWrite
- BYTE
Index
Values 0 to 7
- BYTE
d0
- BYTE
d1
- BYTE
d2
- BYTE
d3
- BYTE
d4
- BYTE
d5
- BYTE
d6
- BYTE
d7
RawSend
RawSend
Sends data to the LCD display
- BYTE
data
The data byte to send to the LCD
- BOOL
type
A boolean to indicate command type: true to write data, false to write a command
RemapCharacter
RemapCharacter
Assigns a remap character allowing the PrintString function to automatically swap between pre-defined characters. The characters can be custom (in the range 0-9) or can point to an existing character in the LCD character map.
- BYTE
RemapIdx
Remap Index, Range: 0 to (Remap Characters - 1)
- BYTE
SearchCharacter
Character to look for a replace
- BYTE
ReplacementCharacter
New character value to use in place of the search character.
ScrollDisplay
ScrollDisplay
- BYTE
Position
Holds the number of positions to shift the display
- BYTE
Direction
0 = left, 1 = right
Start
Start
Startup routine required by the hardware device. Automatically clears the display after initialising.
Data 0 (11)
Data 1 (12)
Data 2 (13)
Data 3 (14)
Register Select (4)
Enable (6)
Component Label
Component Label Scale
Text Colour
Colour of the font characters drawn on the display
Text Background
Colour surrounding the font characters drawn on the display
Display Background
Colour of the background of the display
