| Author | Matrix Ltd |
| Version | 2.0 |
| Category | LEDs |
LED Matrix component
LED Matrix component designed to work using a HT16K33 LED driver IC. Can drive up to 16 x 8 (128) LEDs. Includes support for 8x16 Backpack, 16x8 Featherwing, 8x8 Backpack and Custom.
Please click here to download the component source project: FC_Comp_Source_temp/LED_Matrix_HT16K33.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/LED_Matrix_HT16K33.fcfx
Example to display a bitmap image on the LED matrix using the Bitmap Drawer component.
File:HT16K33 Bitmap.zip
ClearLEDs
|   | ClearLEDs |
| Sets all of the LEDs in the matrix to the off state. |
|  - VOID | Return |
DisplayString
|   | DisplayString |
| Prints an ASCII string onto the LED Matrix a column at a time. |
|  - STRING | Data |
| Data string to display on the LEDs |
|  - UINT | Animation_Delay |
| Delay in milliseconds between writing to the next column |
|  - BYTE | Leadout |
| Allows the text to scroll completely off the display before returning 0=No, 1=Yes |
|  - BYTE | Add_Spaces |
| Add spaces between each ASCII character 0=No, 1=Yes |
|  - BYTE | Orientation |
| 0=Normal, 1=Rotated 90 Degrees |
|  - VOID | Return |
|   | Initialise |
| Configures the I2C peripheral and sets up the HT16K33 IC ready to drive the LEDs. |
|  - VOID | Return |
SetBrightness
|   | SetBrightness |
| Configures the brightness of the LEDs by varying the On portion of the duty. |
|  - BYTE | Brightness |
| Range: 0-15 - 0 = Min Brightness, 15 = Full Brightness |
|  - VOID | Return |
ShiftColumns
|   | ShiftColumns |
| Shifts the columns one place left or right.  Used for things like displaying scrolling text. |
|  - BYTE | Direction |
| 0 = Shift Left, 1 = Shift Right |
|  - VOID | Return |
WriteColumn
|   | WriteColumn |
| Allows a single column of 8 LEDs to be controlled in a single action. |
|  - BYTE | Column |
| Range: 0-15 |
|  - BYTE | Data |
| Data to display on the column of LEDs |
|  - VOID | Return |
WriteCommand
|   | WriteCommand |
| Writes a command. |
|  - BYTE | Command |
|  - VOID | Return |
WriteLED
|   | WriteLED |
| Allows a single LED to be controlled using the basic column / row coordinate system. Each column is comprised of 8 rows. |
|  - BYTE | Column |
| Range: 0-15 |
|  - BYTE | Row |
| Range: 0-7 |
|  - BYTE | Data |
| 0 = LED Off, 1 = LED On |
|  - VOID | Return |
WriteLEDXY
|   | WriteLEDXY |
| Allows a single LED to be controlled using a more standard X, Y coordinate system. 0,0 refers to the bottom left hand LED. Only works with the fixed display modules, custom module not supported. |
|  - BYTE | X |
| X coordinate. Range: 0-15 |
|  - BYTE | Y |
| Y coordinate. Range: 0-15 |
|  - BYTE | State |
| State 0=Off, 1=On |
|  - VOID | Return |
WriteRegister
|   | WriteRegister |
| Writes a value to a register. |
|  - BYTE | Address |
|  - BYTE | Value |
|  - VOID | Return |
|   | Properties |
|   | Display Module |
| Selects the layout of the module you are controlling.  Several modules are available in pre wired formats to provide an off the shelf LED matrix. |
|   | LED Count |
| Total number of LEDs in the component |
|   | Connections |
|   | Slave Address |
| Sets the software device slave address. Must be configured to match the wiring of the three hardware address pins. |
|   | Channel |
| Channel selection |
|   | Baud Select |
| Baud rate option selector |
|   | Baud Rate |
| Baud rate to be used |
|   | Stop Delay |
| On older microcontroller devices there is a potential for the I2C hardware channel to lock up if there is not  a 10ms delay between an I2C stop event and the next I2C start event.  Most modern microcontrollers will not have a problem so this property can be disabled to speed up the  I2C communications. |
|   | SDA |
| Pin used for SDA (data signal) |
|   | SCL |
| Pin used for SCL (clock signal) |
|   | Colours |
|   | On Color |
| Simulated colour of the LEDs when switched On |
|   | Off Color |
| Simulated colour of the LEDs when switched Off |
|   | PCB Colour |
|   | Label Colour |
|   | Simulation |
|   | Simulation Type |
| Sets the simulation type. Component GUI allows the object on the panel to reflect what the reakl life LED matrix should do. I2C Injector allows the I2C communications to be simulated via injectors. |
|   | GUI |
|   | Column Spacing |
| Simulation column spacing |
|   | Width |
| Simulation LED width |
|   | Row Spacing |
| Simulation row spacing |
|   | Height |
| Simulated LED height |
|   | Depth |
| Simulated LED Depth (3D environments only) |
|   | LED Shape |
| Simulated LED basic shape |
