Component: LIN Master (Comms: Interface)
Revision as of 12:02, 3 February 2023 by Wiki bot (talk | contribs)
Author MatrixTSL
Version 1.2
Category Comms: Interface
LIN Master component
Low level routines for controlling a LIN master (1.3 & 2.0) interface.
Please click here to download the component source project: FC_Comp_Source_temp/LinMasterV2.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/LinMasterV2.fcfx
Fc9-comp-macro.png Initialise
Initialise the component
PowerDown
Fc9-comp-macro.png PowerDown
Power Down the device
SendMessageRxData
Fc9-comp-macro.png SendMessageRxData
Sends message with specified identifier and awaits a reply from a slave. Returns the number of data bytes received, 254 for a timeout or 255 for a checksum error.
Fc9-u8-icon.png - BYTE Identifier
6-Bit ID field, Range: 0x00 to 0x3F
Fc9-u8-icon.png - BYTE ChecksumType
0=Classic (LIN 1.3), 1=Enhanced (LIN 2.0)
Fc9-u8-icon.png - BYTE ResponseCount
Number of bytes to receive from the slave, Range: 0 to 8
Fc9-u8-icon.png - BYTE ResponseData
Data array to pass the received data
SendMessageTxData
Fc9-comp-macro.png SendMessageTxData
Sends a message to the slave along with data
Fc9-u8-icon.png - BYTE DataCount
Number of data bytes to transmit to the slave, Range: 0 to 8
Data array to send to the slave
UpdateBaud
Fc9-comp-macro.png UpdateBaud
Changes the UART Baud rate. 0=1200, 1=2400, 2=4800, 3=9600, 4=19200, 5=38400, 6=57600, 7=115200, 8=250000
Fc9-u8-icon.png - BYTE new_baud
WakeUp
Fc9-comp-macro.png WakeUp
Wake Up the device
Fc9-conn-icon.png Bus Options
Fc9-type-16-icon.png Channel
Fc9-type-16-icon.png Baud Options
Fc9-type-21-icon.png Receive Timeout
The number of milliseconds to wait for incoming data to be received from the slave.
Fc9-type-5-icon.png TX
Fc9-type-16-icon.png TX Remap Pin
Allows the hardware transmit pin to be configured from a list of available pins based on your target device,
Fc9-type-5-icon.png RX
Fc9-type-16-icon.png RX Remap Pin
Allows the hardware receive pin to be configured from a list of available pins based on your target device,
Fc9-type-5-icon.png CS
LIN bus chip select pin
Fc9-conn-icon.png Simulation
Fc9-type-16-icon.png Console Format
Controls if the data is shown as a log with time and date stamps or just as raw data
Fc9-type-21-icon.png Console Columns
Fc9-type-16-icon.png Data Source
Simulation data source used to allow the component to connect to various remote devices Nothing - Simulation data is ignored COM port - Routes the communication data to and from a physical or virtual COM port API - Routes the communication data via a data injector component on the Panel.
