Component: Linear Actuator (Mechatronics)
Revision as of 12:02, 3 February 2023 by Wiki bot (talk | contribs)
Category Mechatronics
Linear Actuator component
Creates a linear actuator that can be used with the various motor components via a coupling or gearbox.
Please click here to download the component source project: FC_Comp_Source_temp/LinearActuator.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/LinearActuator.fcfx
CheckLimits
Fc9-comp-macro.png CheckLimits
Checks to see if either limit switch is active. Returns 1 if min switch is active, 2 if max switch is active, 3 if both switches are active else returns 0.
Rotate
Fc9-comp-macro.png Rotate
Simulation Rotate function to allow accurate rotation during simulation. Automatically called by any attached coupling or gearbox component.
Fc9-f32-icon.png - FLOAT Angle
Amount to rotate the shaft input in degrees
Fc9-conn-icon.png Actuator Properties
Fc9-type-15-icon.png Translation Per Rev
Sets the amount of translation for each revolution of the input shaft. M4 = 0.7mm M5 = 0.8mm M6 = 1.0mm M8 = 1.25mm M10 = 1.5mm
Fc9-type-15-icon.png Travel
Amount of travel in the linear actuator before hitting the end stops
Fc9-type-15-icon.png Revolutions
Number of revolutions the actuator can travel
Fc9-type-1-icon.png Colour
Sets the colour of the actuator and end stops
Fc9-type-17-icon.png Output
Output connection for example an end tool or another linear slide and motor group.
Fc9-type-15-icon.png Output Offset X
Distance along the X axis from the center of the coupling to the center of the output object.
Fc9-type-15-icon.png Output Offset Y
Fc9-type-15-icon.png Output Offset Z
Distance along the shaft from the center of the coupling to the center of the output object.
Fc9-conn-icon.png Limits
Fc9-type-16-icon.png Limit Type
Controls if limit switches are available on the linear actuator.
Fc9-type-16-icon.png Switch Polarity
Sets the active polarity of the input switches. Active low are often used to help reduce noise on the switch inputs.
Fc9-type-5-icon.png Min Switch Pin
Pin connection used for the minimum limit switch
Fc9-type-5-icon.png Max Switch Pin
Pin connection used for the maximum limit switch
