Component: Maze Generator (HP458) (Scenarios)
Revision as of 12:02, 3 February 2023 by Wiki bot (talk | contribs)
Category Scenarios
Maze Generator component
Creates a simulation only randomised maze out of standard micromouse maze walls and pillars. Compatible with the Formula Flowcode robot.
Please click here to download the component source project: FC_Comp_Source_temp/MazeGenerator.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/MazeGenerator.fcfx
GenerateMaze
GenerateMaze
Clears the current maze and generates a new maze over the top. Automatically called when the size of the maze is altered.
Generation Settings
Maze Generation
Specifies how the maze is generated. Manual - All walls are shown, clicking on a wall will remove it while the switch remains active. Random - A random maze is generated
Contained
Decides if the maze is contained or if there are openings to allow the robot to escape the maze for obstacle course type simulations. No - Creates two holes in the side walls of the maze to match the longest path possible through the maze Yes - The maze is self contained
Dimensions
Width (Walls)
The number of micromouse walls wide the maze should be
Length (Walls)
The number of micromouse walls long the maze should be
Cell Count
The total number of individual cells the maze will have
