Component: DC Motor (Half Bridge) ()
Revision as of 12:02, 3 February 2023 by Wiki bot (talk | contribs)
Author Matrix Ltd.
Version 1.1
Category
DC Motor (Half Bridge) component
DC Motor that can be driven in a single direction using digital output pin.
Please click here to download the component source project: FC_Comp_Source_temp/Motor_simple.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/Motor_simple.fcfx
Simple example showing how to drive the motor components and how to create sub assemblies attached to the motor output shafts in the simulation panels. FC6 Icon.png Motors
Start
Fc9-comp-macro.png Start
Set the motor running by turning on its pin.
Stop
Fc9-comp-macro.png Stop
Turn off power to the motor by turning off its pin.
Fc9-type-5-icon.png Pin
Fc9-type-16-icon.png Active State
Fc9-conn-icon.png Motor Settings
Fc9-type-16-icon.png Direction
Fc9-type-15-icon.png Speed
Speed of the motor when turned on.
Fc9-type-15-icon.png Acceleration
Speed change per second when the motor us powered. Set to zero for instantaneous speed changes.
Fc9-type-15-icon.png Deceleration
Speed change per second when the motor is coasting with no power. Set to zero for instantaneous speed changes.
Fc9-type-7-icon.png Show Actuator
When activated, an actuator will appear so that the animation can be seen more easily.
Fc9-conn-icon.png Linkage
Fc9-type-17-icon.png Target Object
An object or group to link the motor to - the object will move along with the motor.
